DIY Tealight Candle Holder
7,494
334
11
Published
Introduction: DIY Tealight Candle Holder
About: I like to make fun projects and document it all for my channel BCDesign on YouTube!
I made a Tealight Candle Holder from Blackthorn wood and walnut.I think it would be a very nice decoration for tables at a wedding or another special occasion. I made a YouTube video of the build process,please subscribe and thumbs up!
Step 1: Split the Wood & Flatten the Top
  • I used my favorite Hultafors axe to split the log and level the top.
  • I used the axe to remove as much wood as I could before sanding it perfectly flat as it would save alot of time at the sanding stage.
  • be careful not to chop your fingers off!
Step 2: Make a Dado
  • I set the depth of cut on my mitre saw
  • I made a dado in the bottom of the log by making multiple cuts
  • I test fitted my walnut piece until it fit snuggly.
  • I used a chisel the clean out the excess wood from the dado.
Step 3: Glue & Clamp
  • I cut the walnut scrap to size on the mitre saw
  • I used this piece so the candle holder would sit level and not roll around
  • I glued and clamped the wall nut piece in over night
Step 4: Drill the Candle Holes
  • I used my redneck drill press and a 38mm spade bit to drill the candle holes.
  • most good quality tealights are 38mm in diameter including their metal holder.
  • If you use cheaper tealights they may be bigger than 38mm
  • Mark out the 3 places where you will drill carefully
  • Then drill them out with care.
Step 5: Spray on Your Finish
  • I used a polyurethane spray finish on the holder
  • I sprayed on 3 coats sanding lightly between each coat.
  • Use a paint brush to stop any runs spreading before the polyurethane drys
  • using the brush will save you lots of time on sanding.
Step 6: Add Some Candles & Light Them
  • I added some lavender scented tealights
  • The pink colour of the candles went well with the pink and purple colours through the wood.
  • I made a youtube video of the build process
  • Please subscribe and thumbs up!
If you like this video here is a link to my channel!Thanks for watching!
https://www.youtube.com/user/bazza866/videos
Step 7:
2 People Made This Project!
  • Water Contest
    Water Contest
  • Oil Contest
    Oil Contest
  • Creative Misuse Contest
11 Discussions
Looks really nice - will be stealing this idea for something to build and include in my other half's Christmas box :o)
