Blank CD Case Cooler
7,976
8
26
Published
Introduction: Blank CD Case Cooler
A hack with some simple things, has some practical uses, totally open project. Feel free to be creative. Oh and if im retarded and u wanna complain or whatever hit me at d_j_M_R_R@hotmail.com being has it this is my first instructable.
Step 1: Gather Stuff
Materials i used:
Wire stripper
9v battery
poster putty
old 2 pin 80mm 12v dc compy fan
Blank Cd Case of course
Dremmel
Exacto Knife
Pen
4 1 1/4 drywall screws or 1 inch should work fine
4 erasers...the cheap little thing kinds
Duct Tape
4 gold snap things, the stuff used in kindergarten to make paper jointed creatures
2 paper clips
2 conductor wire or whatever
And thats pretty much it
Step 2: Cutting Hole
Cutting a hole in the top of the cd case is probably the toughest to do out of the project
K outline it with a fan girll or something
a circle
then grab x-acto
scrap over it and all
then start to add pressure
then cut
Step 3: Attach Things
Grab dry wall screws
hand drill through plastic
OH quick btw / bactrack if you got a lot of rough edges in the hole use a dremmel w/ a sand bit to file down
Screws should hold fan fine
flip over top and add erasers on screw ends for elimation of the pointyness
Step 4: Attach More Stuff
K grab 9v battery stick poster putty on bottom and stick on top of middle of grill
Then strip some wire and cut some of 2 conductor, 6 inches is plenty
Then strip and cut off end on 2 pin ball bearing fan connector
then braid wire
rember black is negative red and white are positive make sure witres when assembled on ghetto switch line up right
Step 5: MAking the Ghetto Switch
Cut 2 rectangles out of duct tape
same size
put sticky side together
then insert snaps make sure they are all alligned so no single snap touches another
look on back
ref pics
then hook wire up
make sure pos and neg are properly alligned left to right top to bottom so neg connects to other neg ; pos connects to other pos
add paper clips one can constantally link between two snaps
other one acts as a switch to complete circut turning it on and off
    • Clocks Contest
      Clocks Contest
    • Oil Contest
      Oil Contest
    • Water Contest
      Water Contest
    26 Discussions
    k-man
    12 years ago
    what does cooling do to the cd's? does it just keep their quality?
    CDs breathe passively, like insects. They need air movement or they can't breathe. This fan will prevent your CDs from suffocating.
    now that i got that out of my system. what about a soldering fume arrestor. get some dryer hose and duct tape or zip ties and run the hose to a vent fan in your house.
    Yea i kept poking holes in the top of the case and they would always go bad.
    Hay I just saw this. I put my beer in it and it stays cool by evaporation!
    Why not just take the lid off the case?
    Yeah...I must have been high when I made this...the oh so many months ago that I posted it...I enjoy plants...sometimes...especially the green ones hahaha
    Am I high? Its a CD preservation vacuum to prevent CD flesh eating Escherichia Coli population explosion. Good. Now I can Sleep safe! :-)
    :-\ im confused! What does this do? just keep blank cds cool 4 some reason??? (my pc room is in a cool basement, how would this benefit me...?)
    how many batterys per week would you go through? Too many.
    Should be powered otherwise, e.g. USB. I can't see where the air exits the case, or how it ventilates other than the top CD? Does this have a serious purpose?
    Umm yeah thats basically it: Add some resistors...keep it from draining maybe prac uses: summer heat issues maybe dk hoorah for my first crappy instructable peace
    this could be applied to the side of a computer case that desperately needs a blowhole. the blank cd cylinder part could contain some sort of dust filter for the thing ( i dunno , just thinking of ideas other than keeping blank cd's cool )
    I used to make switches like that...
    ....finally someone has addressed the growing issue of blank cd mistreatment...i had petitioned the aspca for years about this but they woudln't listen.... pretty low quality here...but at least it's not usb powered or made of k-nex
    I dont get it..
