Hi!
This is a step by step instruction of how to make an blanket of own Mario ♥
Made of Laura Muñoz from Spain ^ 3^
The blanket is made of square crochet, exactly for 238 squares in 15 hours
You need:
- wool yarn
         Colors:
                      - Blue
                      - Red
                      - Brown
                      - Yellow
                      - Black
                      - Skin color
- Crochet hook size 2 mm or 3 mm depend of wool
- A needle for join squares
-Scissors
-Paint for the drawing - 8bit
- With much love and affection
Step 1: Square
For the squares is very easy
1- First, make a chain of 4.
2- Then, make a double crochet/treble in the chain stitch furthest from the hook.
3- Make another double crochet/treble in the same chain stitch. Now you have the first side completed.
4- Chain 2.
5- Make 3 double crochet/treble in the same chain stitch. Chain 2 again, make another 3 double crochet/trebles in the chain stitch and finally chain 2.
6- Join with slip stitch/single crochet in the top of the original chain and then slip stitch/single crochet your way through the top of the double crochet/treble stitches - as indicated by the arrows. Make sure you go through both of the 'legs' of the V of the stitch.
7- Now you get to the chain space. If you are continuing with the same colour, as I am here, just make a slip stitch/single crochet around the chain and then chain 3.
8- However, if you are changing colour, make the slip stitch/single crochet into the first chain stitch, then make a slip stitch/single crochet around the chain and then chain 3. This should ensure that your second colour is fastened properly
9- You should now have someting that looks like this
10- Make 2 double crochet/treble in the chain space, then chain 2. Make another 3 double crochet/treble in the same chain space. That is the first corner completed. For the following corners, make 3 double crochet/treble, chain 2, 3 double crochet/treble in each chain space.
11- You should now have something like this. Slip stitch/single crochet into the top of chain 3 you did at the beginning of the round. Then, like you did in the last round, slip stitch/single crochet through the top (arrow) of the double crochets/trebles to get you to the first chain space.
12- Repeat the first corner of the previous round, then make 3 double crochet/trebles in the next space and continue like this until you get to the end of the round. Every other round will be like this one, but with an increasing number of space between the corners. You should not make chain stitches anywhere else but in the corners
vbrito says: Nov 3, 2011. 10:49 AM
I don't really understand the squares...
Arual (author) says: Nov 3, 2011. 11:54 AM
First of all, Do you know how to crochet and knit? .....
vbrito says: Nov 3, 2011. 12:21 PM
Crochet no
Knit kind of...
I'm relearning...
Butr the squares par is confusing...
It's ok let it be
I'll ask someone in my family
kaylaangelkisses says: Aug 16, 2011. 7:51 AM
My little brother loves mario.he would die for this.Thanks!
acody says: Jul 18, 2011. 8:57 PM
My grandson, who is six years old loves Mario and found this site for me and asked if I would make this blanket for him. So i will try my best and let you know how it turns out.
Arual (author) says: Jul 19, 2011. 3:47 AM
Yes, I hope that you try it and the result will be fantastic, You will see , it's very easy!
Lucky! ♥
tonysoprano6379 says: Jun 8, 2011. 6:18 PM
Great Instructable. This has given my wife a TON of Great ideas. WE LOVE IT!!!!!!!
HungryT says: May 24, 2011. 12:27 PM
Hi! This is fantastic. We're having a contest over on Easy Crafts and I would love it if you would add this there: http://easycrafts.wikia.com/wiki/Spring_Craft_Contest!
Arual (author) says: May 24, 2011. 1:26 PM
In contest? But I dont from to US, I can't. --> "Open to US residents age 18 years or older."
sorry >o<
HungryT says: May 24, 2011. 2:07 PM
Oh! That's too bad. Can I post your project on this site and link to it here on Intsructables?
Arual (author) says: May 24, 2011. 4:30 PM
okeyy! >p<
schapman2 says: May 12, 2011. 5:32 PM
i there - I’m currently writing an article about bizarre, unusual and wonderful craft projects. I would love permission to publish this image, along with some text about the Mario project, and a link back to this article.
The article will be a slideshow of photos of unusual craft projects, and it is to complement an article we have about guerrilla knitting.:
http://lifestyle.ninemsn.com.au/article.aspx?id=8244625
If you could let me know by as soon as possible, that would be great.
Thanks and regards!
Arual (author) says: May 13, 2011. 4:40 AM
ok! It seems a great idea!
Promote my best image! ^ o^
If you seems well, put my name: Laura Muñoz Isidro and country: Spain
poofrabbit says: Apr 26, 2011. 5:12 PM
Very well done!
Arual (author) says: Apr 27, 2011. 4:28 AM
thank a lot! ^ o^
the_burrito_master says: Mar 10, 2011. 10:16 AM
My mom loves to crochet ,maybe she can make this for me.
mom2eight says: Mar 14, 2011. 8:22 PM
Maybe she can!
Arual (author) says: Mar 10, 2011. 10:29 AM
yes! It's so warm in the winter or .. also as carpet but if you have a dog better not. Or on top of the bed
the_burrito_master says: Mar 12, 2011. 12:04 AM
i just posted it on my moms FB ,asking her to make it for my birthday. I might make my own pattern for my mom to follow cause i want it to fit my bed, your looks a little small.
if you can just add it to the 2nd step and i'll even count up the squares it uses.
69 red
51 tan
43 brown
227 black wow that was unexpected.
Arual (author) says: Mar 13, 2011. 3:11 AM
now , I added in the 2nd step this change
the_burrito_master says: Mar 13, 2011. 12:04 PM
I don't see it are you sure you saved it?
Arual (author) says: Mar 14, 2011. 4:42 AM
Yes, is here
http://www.instructables.com/id/Blanket-MARIO/step2/Join-squares/
piterpanda says: Mar 14, 2011. 5:34 AM
que grandeeee
esrun says: Mar 13, 2011. 9:40 PM
I really like this but have never tried to crochet before. Is this project within the realms of a completely newbie crocheter/stitcher/fabric worker?
Arual (author) says: Mar 14, 2011. 4:41 AM
Yes! only have to do "the squares" but first you have to learn the basic crochet
The Gingham Ginger says: Mar 10, 2011. 3:03 PM
This turned out great. Been thinking of making a granny square quilt. Thanks for the instructions. This might be it.
blodden says: Mar 10, 2011. 9:45 AM
I have found my next project, thank you. :)
Arual (author) says: Mar 10, 2011. 10:17 AM
I'm so happy that you have found an idea ;- )
tob11 says: Mar 10, 2011. 1:42 AM
cool!
Hir0 says: Mar 9, 2011. 11:33 AM
its wonderful!!! i will try to do my own mario hehe
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
