3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bleach Spritz Clothing
Renewing my all-too-brief love affair with bleaching my own designs into clothing
Step 1What this is
What this is
This is a really simple way of putting text or other designs onto a T-Shirt. It takes about 1 minute, once you have all the materials. Basically, I put bleach into a perfume spritz bottle, spelled things out with magnetic refridgerator letters, and then spritzed over them onto a dark thrift store shirt. It works really well--Check it out!
enjoy,
alex
http://www.artiswrong.com
67 comments
1-40 of 67next »
Apr 15, 2012. 6:39 PMtyzzy says:
you can also spray it with peroxide to deactivate the bleach
Jun 30, 2011. 9:16 AMredfro2 says:
Fun foam like you would buy in a craft store (Michaels, Hobby Lobby, etc) makes for a good stencil too. It's sold in flat sheets like sheets of paper. They can also be found in various pre-cut shapes. I bought a box full of fun foam snowflakes of all different shapes and sizes, dropped them randomly on a dark blue t-shirt, bleached, and voila! Pumpkin stencils work too for ghoulish t's.
Oct 13, 2011. 11:31 AMamandaggogo says:
Foam sheets are a really good idea. Never would have thought of that.
I was using card stock just because it's all I had on hand. Haha
Aug 14, 2011. 6:10 PMBigNateMI says:
We used this technique for entertaining the kids at a nurses' union sign making event. It worked out perfectly. By the end of the event, the adults were lining up to have their union-issue red T-shirts personalized. The kids did the layout, and the rinsing with a hose. Adults did the bleach application, as nobody wanted to see a kid get a face-full of bleach, even within spitting distance of a hundred RNs. We used steel baking pans inside the shirts. and magnetic foam letters for a resist. We also used DIY'd foam stencils with a dusting of Elmer's spray adhesive for the graphics. As we had most of these things on hand, cost was $4 for a new T-shirt, or free if you had your own.
Aug 10, 2011. 7:48 PMsharkstun97 says:
*Gasp* To a polo shirt! lol but nice tutorial
Mar 31, 2009. 10:25 AMXxGOTARxX says:
My question that I have been hunting all over the net to find is... Is it possible to bleach dye to get different colors. At least is it possible to do a heavysolution and then a lighter one later on the same shirt to atleast make two shades. Would adding food coloring to the bleach solution cause a slighty different color tint?
Apr 8, 2010. 4:33 PMsurroundsound5000 says:
 I think the fod colouring would just wash out; but what you could do is either use clothes dye applied directly in certain spots after bleaching, or:
-Bleach in a design (Eg, onto a blue shirt)
-Dye the whole shirt with red (Making the bleached bit red and the rest purple)
-Bleach some of the red section (Making it ~white/pale)
Giving a three tone result.
Jul 16, 2009. 11:25 AMMcblugi says:
The problem with a heavier solution is it might burn through the fabric. If you did 50/50 and maybe 75 % water and 25% Bleach it might work. I don't know about the food coloring but that seems interesting.
Oct 20, 2009. 12:04 AMarie_aroline says:
Great tutorial and so funny!
Jul 16, 2009. 11:30 AMMcblugi says:
I used a cleaner spray bottle and it worked fine. I over sprayed though and when I rinsed it 5 minutes later after blotting it with a paper towel and waiting 2 more minutes, the bleach bled into the back of my shirt which I can deal with but I don't like. Also, using colored shirts instead of black shirts are really cool. I've done a orange one which turns out kind of pink w/ the bleach. The blue one turned out kind of purple. Depending on how much you spray it seems like it would change the color
Aug 8, 2006. 1:02 AMsuicidalwally says:
great idea - i've been looking for a better way to put writing and stuff on shirts than just using sharpies, and this is terrific. one question - any idea how you might do images or designs that aren't purely black and white?
Oct 23, 2008. 5:22 PMCrystalDyes says:
Many black fabrics are actually another color underneath and can be stopped at that point by rinsing in cold water and placing in an Anti-Chlor (from www.prochemical.com)solution. In some cases, manufacturers have an over-run of a particular color of fabric so they will dye it black and use it for something else. The underlying color may or may not pop up. It depends on the initial dye process and whether direct dyes (like Rit) were used or whether a fiber-reactive dye like Procion MX was used. There are several other classes of dyes as well. Some are dischargeable to a rust, cream or near white from black. Some can't be discharged at all. As a dyer, I alway ask for a small sliver of any black fabric I want to buy and go do a bleach test in my car. I do this EVERY time because different bolts from the same company can discharge to different colors. Some colors cannot be discharged with bleach such as Procion MX turquoise. I also use other colored commercial fabrics to bleach besides just black. It makes sense to pick a dark color rather than pastels since you're looking for contrast. There are some very interesting results. Virtually all dyed fabrics are a mixture of dyes to get a particular color. One of the colors used in manufacturing may not be dischargeable and the others will so you will get one of the underlying colors and it will never go to cream or white. Sorry to be so windy here but it is really an involved process that some people have made a career of. Personally, I am a hobby dyer but love the process. Besides spraying, you can make up a thickened bleach to paint on specific area altho now that the Bleach Pen is available I don't do the thickner anymore.
Nov 24, 2007. 3:55 PMrnipper28150 says:
I had one semi-failure when I use just a paper stencil. Some of the bleach soaked through the paper and 'sort-of' bleached the area around my intended design. I tried to correct it and ruined it, or I would show you a pic. I was using half bleach-half water. by the way.
Sep 29, 2006. 12:02 PMkrazykat says:
I tried this bleach spritz and everything went smoothly except it ended up that when I rinsed the shirt, the bleach went onto other parts of the shirt and it looked terrible. Even tried a vinegar/water rinse to stop the bleach. Any suggestions on rinsing while keeping the bleach away from the rest of shirt? THANKS.
Oct 23, 2007. 7:19 PMkottoler ello says:
i wasnt paying much attention in science today, but somewhere in there "bleach is a pretty strong base" actually go into my consciousness. i know that lemon juice is an acid of fair strength and seeing as acids and bases are opposites(but both can be corrosive), if you wanted to neutralize the bleach the chemical knowledge in me would say spray some lemon juice on there. at the least you'll smell lemony and nice :)
Dec 17, 2007. 2:12 PMkillerjackalope says:
yeah but to confuise matters further, chlorine gas makes acid then bleaches litmus... unless it's like chlorine hydroxide... or something
Jul 16, 2008. 9:57 PMWisconsinmom says:
I did this bleaching technique about 10 years ago in wearable art class I took. Try making the stencils out of freezer paper. Cut them out and then iron them on to the fabric with a medium hot iron. Spritz on the 50% bleach LIGHTLY and wait only a minute or two, then plunge into a vinegar and water bath...sorry, don't remember how much vinegar...then wash immediately in cold water.
Jul 16, 2008. 9:58 PMWisconsinmom says:
Forgot to mention that you leave the stencils on until after you get it out of the vinegar water bath. Then, they should just peel right off.
Oct 23, 2008. 5:05 PMCrystalDyes says:
You can use any type of spray bottle, not just perfume bottles. I use the generic household spray bottles I buy at the big-box stores. Diluting the bleach about 50-50 with water will buy additional time to finish spraying the entire area and also decreases the amount of damage bleach does to the fabric. I've also used it at a 20% strength (2 parts bleach to 8 parts water) when working on a large project. A larger spray allows you to get the bleach on faster. The dilution of the bleach is inversely proportionaly to the amount of time it takes to remove the color. Weaker solutions take longer but are less likely to damage fiber. Once the color is removed, you can remove the resist items like the letters or or other objects placed on the garment to block the bleach, before you rinse the garment in cold water and then soak in the Anti-Chlor to completely stop the bleaching action. Washing in a regular wash is then recommended.
Jun 22, 2008. 4:41 PMgannon says:
Hydrogen peroxide or Oxy-Clean will neutralize the bleach. Using vinegar or lemon juice can lead to nasty poisonous gas, I believe, if I remember high school chemistry decades afo.
Oct 23, 2008. 4:52 PMCrystalDyes says:
There is a better & cheaper product called Anti-Chlor available from www.prochemical.com. Otherwise, the bleach will eat holes in the fabric after a few washings. We won't discuss how I know about the holes! There are many classes for dyers re: discharge of color and this is the recommended product. There is also about 3 tons of How-To info on their website on dyeing and painting fabrics.
Oct 7, 2008. 8:25 PMxenor says:
I thought hydrogen peroxide was bleach.
Oct 7, 2008. 7:39 PMmlmommy says:
Use liquid dishwasher detergent. Cascade or just a generic brand. You can paint it on. My kids use cookie cutters dipped in it to make their patterns. Wait about 30 minutes, then wash it off. Easy.
Apr 12, 2008. 3:36 PMplashtic says:
I am SO doing a companion cube shirt. GREAT INSTRUCTABLE - yet so simple :) +1
Mar 11, 2008. 7:27 PMdiello says:
Awesome trick, using magnet letters :) You can also use masking tape and make some neat-o designs. Also, if you want to stop the bleaching process before it gets this far (some like it barely there;), you can dip it in cold water at your desired level of bleach.
Feb 6, 2008. 9:14 AMdrummonkey92 says:
hey, nice instructable...will definately try i think my chemistry teacher said that bleach oxidises things which removes the colour but im not sure how or why!
Aug 3, 2006. 1:49 AMjson684 says:
I have done this too. But I used a more average spray bottle. The kind that usually holds cleaner. It's spray isn't nearly as fine as a spritzer, but I rather like the effect. Almost like paint dripping. The bottle doesn't wear out, so you don't have to worry about that. The way I do it I also get a bottle of vinegar out. In an attempt to neutralize the bleach so it doesn't bleach the shirt too much. I haven't tried it without it, but I like how it looks. Also, you might look into using transparencies. Like for overheads and such. It is more expensive, but you can use it multiple times and not worry about it wearing out. And one final tip, if you use a black shirt you can then use a can of plain spray paint afterward to add a little color. And it is hard to notice on the unbleached portion. The paint will eventually wear off, but it takes some time for that to happen.
Feb 5, 2008. 5:44 PMim_tux says:
if you use a bottle of spray bleach like clorox klean up then ya hold it far away of the mist itll make the image clearer
Apr 21, 2007. 11:23 PMj626no says:
i really like json's work; however, here is my attempt at modern art. my art student friends really liked it, although most people said it was kind of distrubing. i still think its really cool, any questions dont be afraid to ask. if you ever see this json, how did you make that cube...i REALLY like it and wanna make one for myself. thanks
Apr 21, 2007. 11:25 PMj626no says:
ok so this pic didnt post, here it is (im going to try again, no promises)
Apr 21, 2007. 11:30 PMj626no says:
ok so does anybody know how i can post a picture in my comment? it never works for me and its getting really annoying. thanks
Sep 29, 2006. 12:01 PMkrazykat says:
Jan 17, 2007. 10:00 PMAestheticxtattoos says:
let the bleach dry then rinse it off. but don't leave it on too long.
Nov 24, 2007. 3:52 PMrnipper28150 says:
I did one of these with my son (14) and I like the way it turned out too. More importantly, his friends were impressed. I used spray adhesive to glue the printed image to posterboard before cutting out the stencil, then more spray adhesive to glue the stencil to the shirt. I think this made a huge difference in making the image crisp and clean. Check it out!
Dec 17, 2007. 2:14 PMkillerjackalope says:
freaky i'm in the process of making myself a stencil for spray painting the exact same on to a shirt...
Dec 17, 2007. 2:10 PMkillerjackalope says:
hell I was doing this aswell but keep meaning to get positive stencils so i can dot white letters on black, though I could just put black dye in the bottle...
Sep 19, 2007. 2:28 PMsschu05 says:
Im going to try and bleach a hoodie on friday for a concert on saturday-your instructions seems so easy and simple-Thank you!
May 25, 2007. 12:14 PMdchall8 says:
I'm no chemist but I'm pretty sure that if you mixed bleach and vinegar at full strength you'll have a really bad smelling bleach. The only thing I know of that stops bleach is lots and lots of water.
1-40 of 67next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
65
Author:prank
here: http://www.artiswrong.com But really, I'm just this guy. For up-to-the-minute, action-packed updates on my life (and occasional drawings of tapeworms getting it on), check out my blog here: ht...
more »
