3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Blender Lamp
Blender Lamp
Don't throw away that blender just because you want a new one! Turn it into a lamp! I'll show you how easy it can be to turn your blender into a light source.
Step 1Prepare the blender jar
I chose to use this attractive Back to Basics Ice Master 3000 Blender for my lamp. I highly recommend Back to Basics blenders/smoothie makers!
You can choose to leave the blender jar as is, meaning a glossy, transparent glass. I think a frosted look adds a little more and helps to diffuse the light so it's not so bright and harsh.
I had this particular jar sandblasted at a local trophy/sign shop. Since I used to work there I got it done for free, so I'm not sure how much something like that would cost. I blasted the inside and out to give it a nice frosted look.
43 comments
1-40 of 43next »
Jun 19, 2011. 2:27 PMfrdmrckr says:
Ive done this with a toaster and a coffee maker now. ha ha. press the toaster lever down and the light turns on, the heat setting is a dimmer. its fun stuff
Feb 17, 2011. 5:14 PMzomfibame says:
dude, cool instructable. last year I did the EXACT same thing. my model of blender is a little different and I used the HI-LOW switch on my blender as the ON-OFF switch, (it was rated for some pretty high amperage so I figured it was good for a CFL light switch. and I epoxy-glued an old-school ceramic socket in mine instead of a little plastic one like yours) but other than that mine was the exact same thing. great minds think alike I guess. ...... I'll try n' see if I can't get some pics to share. ..... I glued the glass part in place and just lift the lid to change the bulb. ... I'd thought about using the Blend, Puree, Mix, switches to work as a dimmer of sorts but figured that would not work with a CFL so I nixed that idea.
Jan 12, 2011. 7:07 PMbennelson says:
Other ways to "frost" the pitcher -
If it is plastic, lightly sand the inside with a fine grit paper.
For either plastic or glass, you can use a "spray paint" designed to frost bathroom windows for privacy. It also works well with masks and stencils to create frosted designs.
Jan 4, 2010. 12:23 AMflio191 says:
The real question is... will it blend?
Jan 23, 2010. 7:37 PMZaphod Beeblebrox says:
yes but you will get broken glass everywhere
Aug 13, 2008. 3:52 PMtadhg2 says:
this is sweeet !!! i love the idea !!!! what would be really cool is if you had the buttons on the front of the blender turned the light on and off !!! ... i'll have to incorporate that into the design when i do it !
Aug 18, 2009. 11:38 PMDerin says:
I always thought that the P meant "park" LOL
Aug 14, 2008. 5:04 PMtadhg2 says:
sweet, i never thought of having the different buttons do stuff like that. i really want to do this.. now all i need is an old blender,
Nov 21, 2009. 1:44 PMopanocat5 says:
Or a toaster! XD
Sep 19, 2008. 2:16 AMtadhg2 says:
now thats a good idea !!!!!
Aug 23, 2008. 11:42 AMNSB says:
Or, you could make it so each button made it light up a different color.
May 21, 2008. 8:39 AMbovine says:
Wicked cool, can't wait to "liberate" on of these beauties from someone's trash and try this myself. Although I think I'll run the power through one of the switches on the base instead of using the inline switch. great tute
Aug 13, 2008. 3:53 PMtadhg2 says:
hahaha i just posted a comment saying exactly the same thing !, hey great minds think alike !
Jul 17, 2008. 10:04 AMbirtlong says:
I voted for your lamp!! Very awesome!!
Jun 11, 2008. 12:53 PMitobor2525 says:
This is a great idea and instructable. I completed my lamp for outdoor use in the summer. I spray painted the jar w/yellow paint and painted a beach scene (tropical isle) on the front.(photo to follow). I'm completeing a second one as match to 'bookend' the table. I just started making one for my son's college dorm ('Go Pitt!). I'll put in a three way socket and use a 3 way CFL.
Jun 8, 2008. 8:54 PMEtcetera says:
I'm almost there, I have everything, but cannot get my motor out of my blender.
Jun 5, 2008. 12:21 AMSerJ says:
heres mine :) version 2, i left the mains cable wired into the blender switch, and into the breaker switch under the blender jar. if the jar is moved, the light goes off, just like the blender would. also, the 0, 1 and 2 switch positions still apply, - 1 is at 50% brightness, and 2 burns at the 100%, in my case 100W. the pictures dont exactly show this, as was photographed in daylight. looks ok, just need to get the 'sandblasting' effect on the jar now somehow.... any ideas?
Jun 5, 2008. 11:10 AMSerJ says:
thanks!, the blender is the cheapest 11 euro blender that they sell here in the netherlands, branded HEMA (sort of a supermarket, its their own brand). i've never done anything to do with electrics before, and was worried to blow the fuses in my house or something on the first power-up :) have to watch out for any smells or buzzing coming from it now, in case ive done something wrong.. :) wasnt hard to wire in, i left the native blender plug and the cable attached to it, going to the switch which regulates the power supply by itself, and just instead of the motor wired in the light socket contacts. have to get some sandpaper now :) thanks again for the great idea!
May 30, 2008. 7:18 AMboondyke69 says:
You could even do glass ecthing (it it is glass) inside the blender.... like a hamster climbing out... or frogs "help" ... lol
Jun 1, 2008. 10:22 PMdorothyvance says:
Or a little color part way up like you were making strawberry milkshakes or something!
May 30, 2008. 8:34 PMEtcetera says:
Well, I'm definitely off to the garage, to grab that ancient one!
May 22, 2008. 10:51 AMFriedo says:
Sweet idea. Props!
May 21, 2008. 7:48 PMtredfarmer says:
This is amazing! I might just buy a blender just to turn it into a lamp! thanks.
May 21, 2008. 6:42 AMmwwdesign says:
Brilliant! Sorry for the pun. As an industrial (product) designer, I say this is one of the best ideas I have seen on here. Superb.
May 21, 2008. 5:34 PMelialibi says:
Too bad Readymade magazine did this about 4 years ago...
May 21, 2008. 5:13 PMmwwdesign says:
I knew there was some real genius behind it ;)
May 21, 2008. 3:10 PMDIY Dave says:
great idea
May 21, 2008. 11:03 AMWeissensteinburg says:
Nice! Our blender is starting to go, so i'll have to commandeer it when we get a new one.
May 21, 2008. 8:57 AMaphrael says:
it looks like you're making some kind of radioactive milkshake :P this is awesome though, I love the simplicity of it and the way making it into a lamp completely takes the blender out of the context of its function. Now I have to wait for my blender to break :)
May 20, 2008. 10:21 PMshooby says:
Nice work! I would incorporate the switch into the blender buttons though, to complete the effect. More oohs and aaahs when you go to turn it on in front of someone, and the switch is more easily located.
May 21, 2008. 7:19 AMmefromliny says:
What a great idea. I just did it and it completes my kitchen renovation. Great job! Ken
May 21, 2008. 4:32 AMPKM says:
Ooh.. simple, unusual and purty- I like it.
(shoots self in foot slightly)
This would go well in the "Make it Glow" competition to win some sweet bike wheel light things. I've got a vaguely similar project I'm meaning to write up and enter for that competition, hence the self-foot-shootings, but I will acknowledge that yours is cooler than mine :)
May 21, 2008. 4:16 AMBrennn10 says:
This rules!!! I just happen to have an old blender, so I must ask my authoritative figures (ie parents) if I could make it into a lamp.
May 21, 2008. 3:46 AMNeonLime says:
I Would DEFIANTLY Do That If i Had A Spare Blender :O Also If You Cant Find The Stuff At Ikea, Buy A Cheap Small Lamp (I Got 3 For Like $1.50 Each//About 85 Pence) And Broke It Open :D
May 20, 2008. 10:08 PMdarkmuskrat says:
SwEET!
1-40 of 43next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:defpotec
