3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Blender-wacker, A gas powered blender with electric start.
Step 2A better angle
A better angle
It needs a frame of some sort and this is what I had as shop junk. I also wanted to make it simple looking and mechanical so you could easily see how it works.
I bent the steel around a yellow guard post outside the shop then welded the ends together.
Mocked everything up to get a good idea of looks, and placement, then started building brackets. The drill motor bracket gave me trouble so I ended up rebuilding it a few times. I'll get better pics of the final version soon. The motor plate is just a simple sheetmetal plate with holes drilled to match the original screw holes for the weedeater mounting.
The black handle on the right will now serve as a battery box and one of 4 legs.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:stubman
