Blind's Aid
1,271
4
8
Posted in TechnologyArduino
Introduction: Blind's Aid
Helps blind walk without stick. Very cheap and effective :-) :-).
Installed in cap to keep your hand free!!!
Step 1: Things Required
  1. Arduino UNO
  2. Ultrasonic Module HC-SR-04
  3. Jump Wires (F to M)
  4. Jump Wires (M to M)
  5. Connecting Wire ( to connect Arduino to Computer to Program it)
  6. Buzzer
  7. A Cap
  8. Breadboard ( Not much needed)
Step 2: Connections
  • Connect the "Trig" pin of sensor to pin 9 of Arduino
  • Connect the "Echo" pin of sensor to pin 8 of Arduino
  • Power the sensor
  • Connect the "-ive" of buzzer to "Gnd" of Arduino
  • Connect the "+ive" of the buzzer to pin 10 of Arduino
Step 3: Programming Code
Write a code by yourself if you wish so or i have the code.It is below:-
Step 4: Finishing Touch
Now attach this to cap such that the sensor is in the front side of the cap.
  • Spotless Contest
    Spotless Contest
  • Microcontroller Contest
  • Space Challenge
    Space Challenge
8 Comments
hi i was wandering what if the blind man face asmall ditch on the pedistralian road or any hole
can i get the code for arduino in any language???
Interesting idea. Have you by any chance had a blind person try it out? I'd be curious about their feedback.
Thanks for sharing this!
Thanks for your reply. I have made a blind try this and it worked out inside house nut outside it is not possible with small rage distance sensor. instead of the sensor that i use can be replaced by some long range sensor then it can be a perfect solution for visually impaired persons
