3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bling out your Breadboard (how to add LED power indicator to Solarbotics transparent breadboard)
Step 7Making the installation permanent
Let's use more hot-glue to coat these connections and make this installation more robust.
To do this, we'll use a trick I learned from Monty Goodson of Bittybot & "Fatman and CircuitGirl" fame (well, he's in the background lots) :
Use the clear plastic packaging that your breadboard came in to to flatten your hot-glue blobs into a nice, flat surface. Smother your parts in hot-glue, flatten the plastic against it, then stick it in the fridge/freezer for a few minutes. Once all the heat is sucked out of the hot-glue, the plastic will snap off, leaving a nice, flat, molded-like surface!
There. Now you've done one side, go do the other! I built mine so each LED is powered by a different set of power rails, which will make it easy to tell when I'm not powering both sides of the breadboard (that's been an issue for me).
Go out and bling your breadboard!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
68
Author:Solarbotics
