Remove these ads by
Signing UpStep 1Materials needed
So here is a list of the Materials that I used and where I got them:
Blue Blinking LEDs ( Best HongKong )
Resistors ( Best HongKong )
Copper Metal Foil Tape (Micheal's Arts and Crafts)
Poster Board (Micheal's Arts and Crafts)
Old Phone Charger ( I just wrote a staff email at my work and had everyone bring there old phone chargers in, now I have a stock pile different voltage chargers!)
Piece of sheet metal (Home Depot, Lowe's, probably any hardware store)
Four Small Bolts with Nuts (Home Depot, Lowe's, probably any hardware store)
Four Small Rubber Caps that fit over the ends of the Bolts (Home Depot, Lowe's, probably any hardware store)
On the phone charger there is a positive and negative wire, so you just solder the positive wire to the positive copper tape, and do the same with the Negative. If you are not sure which is the positive and negative, you can do a test with LED's, make sure you use the correct resistor for the test though so you don't burn out the test LED.
Thanks and great instructable!!
http://www.instructables.com/id/Add-sound-reactive-LEDs-for-any-speakers/
http://www.instructables.com/id/Blinking_LEDs_to_Music/
and made it i have yt vid link there i ncomments
thanks a bunch now i will try it on a bigger scale :D
You can go to led.linear1.org/led.wiz and figure out which resistors you need, It is a VERY handy website, I use it all the time! I hope this helps, if you have anymore questions please let me know!
Take a look at that website and go from there, if you are still not sure you can email me your info (how many LED's, what voltage you are using, along with the Ohms available on you power supply) and I can help you out.
SO going off of that, you want to have it the same basic setup that I was using, which is one resistor to each LED... so that means that you need to know what resistor to use with that power source to power one LED.... which when you think about it, when you put in the number of LED's in the calculator just put ONE! Easy as that, now you know what resistors to use.
If you were to do what is explained above the calculator would tell you that a 220 Ohm 1/4 watt resistor would be the correct fit.... so just go out and buy one resistor per LED and you got it! Hope that helps, and when it comes to problem solving, you need to think outside the box!
