3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Blinking LED Mood lighting
Step 5Soldering the LEDs
Soldering the LEDs
So as you know there are a lot of LEDs in this project so that means that there is a lot of soldering. It gets a little manotonous so get ready!
After doing some testing with the LEDs that I bought, I figured out that when they blink it actually cuts power from the light itself, so if you were to put a couple LEDs in an array they would blink together and not at there own pace, which would be cool if you wanted that effect, so maybe another project...
So to get the desired look I was going after I need to put each LED on its own circuit persay. So that is each LED needs its own resistor so they will all blink at their own pace.
I used the Copper foil tape as the main circuit for this, and then just soldered the positive leads of the LEDs to one side and the Negative leads to a resistor and then to the other set of copper foil tape.
I made some diagrams below to help with the understanding of this idea of useing copper foil tape, you could use wire for all of this, but I thought this is much cleaner. In these diagrams I use BLUE to represent the negative power from the power supply, and used RED as the Positive power from the power supply.
12 comments
Apr 5, 2010. 3:45 PMlamboboy732 says:
 wow it looks really professional. Nice Job!
Sep 15, 2009. 3:02 PMmightyhogan says:
did you just solder the pos and neg ends of the charger to the foil tape?
Sep 16, 2009. 4:31 PMmightyhogan says:
hey man first let me say thanks for all the help i really appreciate it this thing is starting to look sweet i'll upload some pics when i'm done. but one more question, do you have a rec. on what voltage of charger to use so as not to fry the leds? i noticed you used a 5v
Sep 22, 2009. 3:48 PMmightyhogan says:
thanks again for the quick response. i'd love to see if my leds and resistors are right b4 i solder. so i followed another one of your instrucatbles (great too btw) and ordered 5mm blue blinking leds and 150ohm resistors. will these work with either a 7v or 9 v phone charger or ethernet power supply?
Sep 29, 2009. 1:52 PMmightyhogan says:
ok so i tried to use the calc but the wiring diagrams that they give me a pretty confusing. i was hoping to use the copper tape in the same scheme you had to wire it up. its suggesting wiring two leds togetther pos to neg and the the neg of one to the resistor. i just dont understand how i would lay the tape. Here the break down; esp. if i try for a 3 or 4 row scheme piece of sheet metal 12/24 hoping for 3 rows of leds 4in apart or 4 rows 3 inches apart horizontally and 8 comlumns of leds vertically so either 24 or 32 leds so; 24 or 32 5mm leds.3.3-3.4v 20ma with a 7.7v 700ma power source. your help is greatly appreciated man, i cant thank you enough
Mar 28, 2009. 7:13 PMcatz369 says:
How do you add the charger to it?I'm new at all this and trying to learn.
Sep 17, 2008. 9:25 AMphil_s_stein says:
I've never used the copper tape before. Is it possible to just lay one layer of the tape on top of the other, sandwiching the leads between them? This would save the (enjoyable) hassle of soldiering them all.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
82
Author:seligtobiason(www.SeligTobiason.com)
Well, I feel like I am a pretty regular guy... I work in the Entertainment industry, right now am working for Lucas Animation on a Top secret assignment ;). I love to create things, and build things ...
more »
