Step 6Finishing up!
Some other Ideas that this could be used for... it looks really cool as is, but also if you put a fogged piece of plastic, or glass over it is a nice look. I even put it under a glass fogged table and it created a nice look, if you were to make a custom bar it would be nice lighting to put underneath, there are a lot of options and possibilities!!!
I hope you like this Instructable, and if you have ideas and or make your own versions I would love to hear, and see what you have come up with, thanks for looking, and good luck!
P.S...
Not quite sure but I left it on for a couple hours and it started to make some rust looking dust on it, some kind of corrosion from the electricity or something, but it wipes off without a problem. So one thing to do is to seal the Sheet Metal before starting the project, or if any of you have any suggestions please let me know, and it can help me and anyone that is possibly making this project also, thanks!!
On the phone charger there is a positive and negative wire, so you just solder the positive wire to the positive copper tape, and do the same with the Negative. If you are not sure which is the positive and negative, you can do a test with LED's, make sure you use the correct resistor for the test though so you don't burn out the test LED.
http://www.instructables.com/id/Add-sound-reactive-LEDs-for-any-speakers/
http://www.instructables.com/id/Blinking_LEDs_to_Music/
and made it i have yt vid link there i ncomments
thanks a bunch now i will try it on a bigger scale :D
