This is simple wiring, and all you do is connect each negative terminal to itself and then to the arduino and each positive terminal to a positive pin on the arduino. Remember to connect them in order, ie. the first LED to pin #1 on the arduino and the second LED to pin #2.
This is the arduino code that I wrote.
#define LED01 13 // says led is at # 13
#define LED02 12
#define LED03 11
#define LED04 10
#define LED05 9
#define LED06 8
#define LED07 7
#define LED08 6
#define LED09 5
#define LED10 4
#define LED11 3
void setup()
pinMode(LED01, OUTPUT); // digital pin is output
pinMode(LED02, OUTPUT); // digital pin is output
pinMode(LED03, OUTPUT); // digital pin is output
pinMode(LED04, OUTPUT); // digital pin is output
pinMode(LED05, OUTPUT); // digital pin is output
pinMode(LED06, OUTPUT); // digital pin is output
pinMode(LED07, OUTPUT); // digital pin is output
pinMode(LED08, OUTPUT); // digital pin is output
pinMode(LED09, OUTPUT); // digital pin is output
pinMode(LED10, OUTPUT); // digital pin is output
pinMode(LED11, OUTPUT); // digital pin is output
void loop()
digitalWrite(LED01, HIGH); // turns LED on
delay(30);
digitalWrite(LED02, HIGH); // turns LED on
delay(30);
digitalWrite(LED01, LOW); // turns LED off
delay(30);
digitalWrite(LED03, HIGH); // turns LED on
delay(30);
digitalWrite(LED02, LOW);
delay(30);
digitalWrite(LED04, HIGH); // turns LED on
delay(30);
digitalWrite(LED03, LOW);
delay(30);
digitalWrite(LED05, HIGH); // turns LED on
delay(30);
digitalWrite(LED04, LOW);
delay(30);
digitalWrite(LED06, HIGH); // turns LED on
delay(30);
digitalWrite(LED05, LOW);
delay(30);
digitalWrite(LED06, LOW);
delay(30);
digitalWrite(LED08, HIGH); // turns LED on
delay(30);
digitalWrite(LED07, LOW);
delay(30);
digitalWrite(LED09, HIGH); // turns LED on
delay(30);
digitalWrite(LED08, LOW);
delay(30);
digitalWrite(LED10, HIGH); // turns LED on
delay(30);
digitalWrite(LED09, LOW);
delay(30);
digitalWrite(LED11, HIGH); // turns LED on
delay(30);
digitalWrite(LED10, LOW);
delay(30);
digitalWrite(LED11, LOW);
delay(30);
delay(30);
delay(30);
delay(30);
delay(30);
delay(30);
delay(30);
delay(30);
digitalWrite(LED07, HIGH);
delay(30);
delay(30);
delay(30);
delay(30);
delay(30);
delay(30);
delay(30);
delay(30);
delay(30);
delay(30);
delay(30);
delay(30);
delay(30);
delay(30);
Mis más sinceras felicitaciones!
Por favor, nunca dejes de trabajar en lo que te guste y si algo o alguien se interpone en tu camino, simplemente ignoralo y sigue adelante!! Es evidente que tienes mucho potencial.
Estaré atento a tu próximo instructable...
(por favor, traduce este texto porque mi inglés es muy malo...)
"I'm 55 and for 6 months I've been trying to program an arduino to make one single LED blink and you only 10 years old have done it in just two weeks? Really it is admirable!
My most sincere congratulations!
Please, don't ever quit working on what you like and if someone or something gets in the way, simply ignore it and keep going! It is evident that you have much potential. I will be watching for your next instructable...
(please translate this because my english is terrible...)"
End translation.
#define LED 13 // says led is at # 13
void setup()
pinMode(LED, OUTPUT); // digital pin is output
void loop()
digitalWrite(LED, HIGH); // turns LED on
delay(100); // wait one second
digitalWrite(LED, LOW); //LED off
delay(100);
