Listening to music on my pc (proudly using WINAMP), I was wondering how would be to have some leds blinking with the sound that came out from the P2 connector, so I decided to make a simple circuit to do that. It worked pretty fine, so I decided to write a HowTo telling step-by-step how to do it. Hope you enjoy it!
If you want to see more of my DIY projects, please, visit my website:
Daniel Spillere Andrade Website
Material and Equipment:
1. 4 LEDs (any collor)
2. P2 plug
3. 2 position switch
4. TIP31 component
5. Box to put all the stuff (if you want)
6. Soldering iron and accessories
7. Cable
Video of the final project:
Step 1: Step 1
This project will work this way, you connect 4 leds in the +12V from your computer, they are soldered to a 2 position switch that will connect to a component called TIP31, this component gets the intensity transmitted by the P2 connector, and with that, makes the leds blink with the music.
You can follow this scheme:
Step 2: Step 2
For this project, I decided to install everything inside a small black box I had here, so I made 6 holes on it. Four in the top for leds and one in each side for the switcher and cables. You can follow by the pictures:
Step 3: Step 3
With the box ready, its time to connect everything. I started with the leds, soldering one small cable connecting each one, so would be easier to arrange them inside the box after.
After connecting all leds, you must connect the cable coming from the leds to the center pin of the switcher. One side of the switcher goes to the middle pin of the Tip31 component, and the other one goes to ground cable.
Step 4: Step 4
Now it’s time to make the P2 connector. You can see that the P2 connector have 3 pins, they are, left channel, right channel and ground. So you have to decide to get the left or right channel and connect with the left pin from the Tip31. Remember that if you connect the P2 using the left channel, if only the right is enabled on the computer, this circuit won’t work. Usually the ground pin is the bigger one, and the other are small and similar. You have to connect the ground from P2 connector to the right pin of the Tip31 (right pin from Tip31 is ground)
Step 5: Step 5
On the other pin from the switcher, you must connect to the ground from Tip31. If the switcher if closing circuit with the Tip31, the leds will only blink if there is any signal coming from the P2 connector, and if it’s in the other direction, the leds will be always ON.
Now it’s time to put everything together in the box, as you can see in this picture, it’s not very organized, but after closing the box, it’ll look much better.
Job's Done! =)
And for more of my DIY projects, please visit my website:
Pasteler0's Tech Stuff
1-40 of 190Next »
kiyu60 says: Oct 26, 2012. 5:08 AM
can anyone help me make a diagram of this with 63 red LEDs
vishal17 says: Apr 18, 2011. 2:52 AM
hi everyone
which transistor can i use other than tip 31?
please answer me fast :)
djbogdy43 in reply to vishal17May 27, 2012. 8:35 PM
BD135,BD137 and BD139! :D
audio_mod in reply to djbogdy43Jun 10, 2012. 1:03 PM
Thanks, i found one of those and the output on the emitter is 5v as opposed to 100v (?) according to the data sheet. Not sure what that means but there is logic there. I'll try, thanks :)
Also in another place i saw about putting a diode on the live input of the audio input. Apparently it will protect positive voltages beign fed back into a soundcard. Any ideas on that one? Which diode?
Thakns, hehe.
audio_mod says: Apr 30, 2012. 11:43 AM
Sorry, can't help anyone below; i am a noob.
I made this and it works - so thanks for an entertaining weekend, but today i am noticing feedback through the speakers when the led are at their max. Any ideas? A bad ground somewhere?
I am using a headphone splitter and i am powering 12 leds from a 12v supply. I put the extra led's in parallel; i figured the power pack was fine, didn't think about the tip31. Am going to blow myself up or worse my speakers? Thanks if ya can help. Alternatively what would i need to put in the circuit to prevent feedback up the P2 connector. :)
sin3kveer says: Apr 5, 2012. 8:06 PM
Hello, I want add 11 White leds in circuit for blink.... tell which transistor i have to use. i am 32 DC power suppy. please answer fast....
whayle says: Oct 12, 2011. 5:22 PM
Hey guys if you want free LEDs go here and sign up free: http://www.points2shop.com/?ref=uin1270958834
All you have to do is sign up, earn points by playing games and doing offers, and get your free rewards. It is actually super easy. You also get $2.50 just for signing up. You can also get free transistors and circuit boards.
Epimetheus says: Mar 2, 2010. 9:09 PM
 Hey guys having a little bit of trouble here. I had this wired up temporarily last week and it worked great! I went to solder it all together today with more LEDs and it didn't work. It would switch on but when I flipped it to the other side nothing happened. I checked the wiring about four times and found nothing wrong, but I went to measure the P2 connection and it wasn't putting out any voltage. Yes it was plugged in, the volume was up, the multimeter was functioning properly and set to DC -- minimal to no voltage on the wires, sound on/off doesn't affect voltage. So I go to cut up another 3.5mm cable, same thing. But when I put the bare wires on the jack of headphones, the sound kicks in? This is not making any sense to me! I'm so lost on this one guys..
absalam in reply to EpimetheusAug 25, 2011. 3:00 PM
Try changing the TIP31...i blew mine once and had the similar problem as yours.
TheMrWolf1994 says: Jul 19, 2011. 9:08 AM
Can I wire together both wires from right and left speaker in one wire to the transistor? Will it be then stronger current through the tip31 and later through the LED's, cause i need a liitle bit stronger current cause my LED's are not blinkinkg so bright..thanx in advice
deko69 says: Aug 18, 2009. 4:56 AM
Hi! I did this mod and it's great. but I want to improve it a little more. I would like to hook up a cold cathode instead of these four leds for more light but the cathode isn't responding to music(won't light up). the cathode requires 12V and the input is 12V (same as leds) but I'm afraid that the current which is flowing trough tip31 isn't enough to light up the cathode Am I right? or what am I doing worong? Is there a way to add other component to make it work? I connected it to the circuit before inverter. should it be after inverter? but I'm afraitd if it won't damage the cathode when I do it that way. please take a look at the picture. any help appreciated
Rhamkota in reply to deko69Jul 3, 2011. 5:20 PM
Most likely the cold cathode can't respond fast enough to the current change, it most likely requires a quarter of a second to warm up, same with with the inverter
aroman3 in reply to deko69Apr 29, 2011. 11:47 AM
man i have done that before ..... just like you show here , it is working ok ... ;)
pyro-jim in reply to deko69Nov 6, 2009. 10:11 AM
what is the inverter for? If the cathode take 12v and you are using 12v then why do you need an inverter? Do you mean that the inverter allows the cathode to use 12v? Otherwise I doubt it should be there.
Arbitror in reply to pyro-jimFeb 26, 2010. 5:10 PM
*Sigh*
Inverters change direct current to alternating current, which is what cold cathode lights need.
SmAsH! in reply to ArbitrorApr 3, 2010. 8:17 PM
They also step it up to something like 500v low A, i did the cc mod at home and it works fine...
yahya2coool says: Mar 27, 2010. 9:21 PM
 if tip 31 is not available then which other transistors can b used? plz help
aroman3 in reply to yahya2cooolApr 29, 2011. 11:46 AM
i am using bd239c i think it is even better :DD
DRodriguez in reply to yahya2cooolMay 3, 2010. 5:12 PM
Here's a great deal on them: 10 for like $3.50 ea.
Ebay
SmAsH! in reply to yahya2cooolApr 3, 2010. 8:15 PM
Almost any npn transistor will work.
aroman3 says: Apr 29, 2011. 11:42 AM
http://www.youtube.com/watch?v=CxqjW6jItMI
Look my video i have made manyy circuits /w leds and cold cathodes ask me everything in the comments on my channel
chandeepa says: Jan 6, 2011. 1:40 AM
cooooool case mod bro.....
Bisjon says: Oct 26, 2010. 7:59 PM
Hi, I was just wondering what "P2" is. I cut the wire from my ipod headphones, but I'm guessing that isn't it because it doesn't work.
zack247 in reply to BisjonNov 26, 2010. 2:26 PM
P2 is a power connector, the plug from your ipods headphones inputs the music into the leds.
look for it (it doesn't have to say "P2" on it. any regular power connector will work) coming out of your power supply
mark catapang says: Dec 6, 2008. 2:28 PM
how cn i add more leds? do i need another tip31? cn u show me a schematic diagram? please response..tnx
deko69 in reply to mark catapangAug 18, 2009. 5:03 AM
parallel connection
anura92 says: Apr 7, 2010. 8:53 AM
Hey... i tried it and it only works when i set the volume knob of my speaker(altec lansing headphone jack) to the highest.... the led i am using was salvaged from a pc fan...
So do i have to change the transistor or change my led to the right voltage ones? Psl help me :(
ST4N13Y says: Jun 7, 2010. 11:02 AM
could i use TIP33 ???? ....and....what i need to change in this scheme if i want to ude 9volt battery ??? thank you very much
Algag in reply to ST4N13YAug 12, 2010. 10:28 AM
add a resistor to the leds or take off an led because they are wired as suck there is a 3v drop (they are 3v each) across each LED so four is the max it could hold BUT if you used 1.5v leds and a 9v battery you could put on 6 leds in that pattern
sharkawien says: Mar 13, 2009. 8:55 PM
where is the P2 connected??
deko69 in reply to sharkawienAug 18, 2009. 5:02 AM
to music output from your computer,ipod etc
bmxlive in reply to deko69Jun 15, 2010. 10:36 PM
i set to max the master volumen & wave level on audio pc control then i plug my p2 to my computer output but the signal in too weak to turn on the led, i plug an earphone and it was working... So i was wondering if the signal of the pc isn´t strong enough to make my circuit works... please help me
funnyman953 says: Jul 11, 2010. 3:32 AM
instead of a 3.5 mm jack can i put a mini micrphone instead cause i will connect it to my power supply's molex connector and will i need a resister if i do use my power supply's molex connector
kishansukumar says: Jul 16, 2008. 12:41 PM
wud a tip32 work insted of a tip31? does it make a diffrence?
Algag in reply to kishansukumarMay 22, 2010. 6:03 AM
 tip32 is pnp not npn
g0tmk says: Apr 7, 2010. 6:58 PM
Hi, I have a bit of a problem with mine.  I set mine up as kind of a pass-through, you plug a jack into the box and the box into speakers.  When I plug speakers into it though, it stops strobing.  How do I manage to get enough power through the transistor to strobe while it is still hooked to speakers?   I am using a 2n7000.  Thanks!
Algag in reply to g0tmkMay 22, 2010. 5:58 AM
 this is an addition to my comment below...be carful though cause it would need a power souce too
Algag in reply to g0tmkMay 22, 2010. 5:54 AM
 you could probably just add an amplifier circuit (two bucks)
hape0 says: Apr 24, 2010. 2:07 PM
if i want to plug it into the electric power of a house, what i have to change??
DRodriguez in reply to hape0May 3, 2010. 5:09 PM
You would need to use a 'wall wart' rated for twelve volts, cut off the plug on the end, find the polarity with your multimeter, and connect it that way.
1-40 of 190Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
