Listening to music on my pc (proudly using WINAMP), I was wondering how would be to have some leds blinking with the sound that came out from the P2 connector, so I decided to make a simple circuit to do that. It worked pretty fine, so I decided to write a HowTo telling step-by-step how to do it. Hope you enjoy it!
If you want to see more of my DIY projects, please, visit my website:
Daniel Spillere Andrade Website
Material and Equipment:
1. 4 LEDs (any collor)
2. P2 plug
3. 2 position switch
4. TIP31 component
5. Box to put all the stuff (if you want)
6. Soldering iron and accessories
7. Cable
Video of the final project:
This project will work this way, you connect 4 leds in the +12V from your computer, they are soldered to a 2 position switch that will connect to a component called TIP31, this component gets the intensity transmitted by the P2 connector, and with that, makes the leds blink with the music.
You can follow this scheme:
which transistor can i use other than tip 31?
please answer me fast :)
I made this and it works - so thanks for an entertaining weekend, but today i am noticing feedback through the speakers when the led are at their max. Any ideas? A bad ground somewhere?
I am using a headphone splitter and i am powering 12 leds from a 12v supply. I put the extra led's in parallel; i figured the power pack was fine, didn't think about the tip31. Am going to blow myself up or worse my speakers? Thanks if ya can help. Alternatively what would i need to put in the circuit to prevent feedback up the P2 connector. :)
All you have to do is sign up, earn points by playing games and doing offers, and get your free rewards. It is actually super easy. You also get $2.50 just for signing up. You can also get free transistors and circuit boards.
Inverters change direct current to alternating current, which is what cold cathode lights need.
Ebay
Look my video i have made manyy circuits /w leds and cold cathodes ask me everything in the comments on my channel
look for it (it doesn't have to say "P2" on it. any regular power connector will work) coming out of your power supply
So do i have to change the transistor or change my led to the right voltage ones? Psl help me :(
