Introduction: Blinky Fish - Kickstarter Project
Picture of Blinky Fish -  Kickstarter Project
Instructions and documentation for the Blinky Fish Kit from March 2013 Kickstarter project.
A PDF copy is attached to this step.
  • Step-by-step assembly instructions
  • Code example
  • Eagle files
  • Fabrication files
  • Invoices
Note: I didn't include instructions for soldering or installing the Arduino software.  Let me know if you have any trouble.
Step 1: The Parts
Picture of The Parts
Here are the parts to make one blinky fish.
1 - Blinky Fish board
3 -  Red LEDs
3 -  220ohm resistors
1 - 10Kohm resistor
1 - right angle header with 6 pins
1 - push button
Some solder
Here is the soldering iron I am using:  Hakko FX888D-23BY Digital Soldering Station FX-888D FX-888
Step 2: Large Images
Picture of Large Images
Here are the large images that shipped with the class room  kits.
Step 3: LEDs
Picture of LEDs
LEDs have to go in like this, or they will not work.
Step 4: Resistors: 220ohm
Picture of Resistors: 220ohm
Step 5: Resistor: 10K
Picture of Resistor: 10K
Step 6: Button
Picture of Button
Step 7: Header
Picture of Header
Step 8: Connect to Arduino
Picture of Connect to Arduino
Step 9: Arduino Code
Here is the code shown in the Kickstarter video.   Hold the button down and the LEDs light up one at a time, release the button and they go off one at a time.
You can copy and paste the code below into the Arduino program, get it here --  http://arduino.cc/en/Main/Software
//****ARDUINO CODE *******// blinky_1  //LED'S on one at a time// LED'S OFF one at a time//Pinsint Led1 = 11;
int Led2 = 10;
int Led3 = 9;
int Button = 12;
int PullUp = 13;
int ButtonState = 0;
int oldButtonState = 0;
voidsetup() {
  pinMode(Led1, OUTPUT);
  pinMode(Led2, OUTPUT);
  pinMode(Led3, OUTPUT);
  pinMode(Button, INPUT);
  pinMode(PullUp,OUTPUT);
  digitalWrite(PullUp, HIGH);
voidloop() {
  ButtonState = digitalRead(Button);
  if (ButtonState != oldButtonState){
    if (ButtonState == HIGH){
      digitalWrite(Led1, HIGH);
      delay(300);
      digitalWrite(Led2,HIGH);
      delay(300);
      digitalWrite(Led3,HIGH);
      delay(300);
    else{
      digitalWrite(Led3,LOW);
      delay(300);
      digitalWrite(Led2,LOW);
      delay(300);
      digitalWrite(Led1,LOW);
      delay(300);
    oldButtonState = ButtonState;
Step 10: More Code - Larsen Scanner
Here is a fun sketch from Kathy, who is a Kickstarter backer --- Thanks Kathy!!
when the button is pressed, it will turn the leds on and blink them like a Larsen Scanner. And if you hold down the button for a few seconds, it'll turn it off.
/////////////////////  ARDUINO CODE //////////////////////////////////////
/*Combines code from "Getting Started with Arduino" by Massimo Banzi
http://shop.oreilly.com/product/9780596155520.do */
from Kathy on Kickstarter - 4/7/2013
int button = 12; //button on pin 12
int pullup = 13; // use pullup on pin 13
int button_state = 0; // see if button has been pressed
int val = 0; // used to store the state of the input pin
int old_val = 0; // previous value of "val"
int delay_time = 250; // how fast or slow the leds blink
void setup(){
// set up leds as output
for (int i = 11; i > 8; i--){
pinMode(i, OUTPUT);
pinMode(button, INPUT); //set up button as input
digitalWrite(pullup, HIGH); // set up the pullup to be on
void loop(){
val = digitalRead(button); //read if the button is pressed
//check to see if there is a change
if ((val == HIGH) && (old_val == LOW)) {
button_state = 1 - button_state;
delay(10);
old_val = val;
if (button_state == 1){
digitalWrite(i, LOW); // if the leds are on and the button is pressed, turn them off
else {
blinky_fish(); // if the leds are off and the button is pressed, turn them on
void blinky_fish(){
//blink the leds on and off in sequence like KITT in Knight Rider (aka Larsen
digitalWrite(i, HIGH);
delay(delay_time);
for (int i = 9; i < 11; i++){
delay(delay_time);
Step 11: Eagle Files That You Can Change
Picture of Eagle Files That You Can Change
Here are the designs in a format that you can can open and change.
A sample version can be downloaded here http://www.cadsoftusa.com/download-eagle/
The schematic is Blinky_2.sch
The board design is Blinky_2.brd
Step 12: Fabrication Files
Picture of Fabrication Files
These are the file that you send to the manufacturer when you order printed circuit boards.
Each file shows a layer of the circuit board.
You can view the actual files with a gerber viewer, but they are difficult to change correctly -- I am using GerbV Gerber File Viewer http://gerbv.gpleda.org/
Step 13: Parts
Here is a large order of parts from DigiKey -
This table does NOT include the 10K resistor and the circuit boards.
Index
Quantity
Part Number
Description
Customer Reference
Unit Price USD
Extended Price USD
160-1853-ND
LED RED 5MM RND  DIF
RED LED
0.05711
$57.11
CF14JT220RCT-ND
RES 220 OHM 1/4W 5% CARBON FILM
220 RES
0.00675
$16.88
952-2328-ND
36 POS SIL VERT PIN HDR
RA HEADER
0.7425
$74.25
4
300
450-1804-ND
SWITCH TACTILE SPST-NO 0.05A 12V
BUTTON
0.07584
$22.75
5
KE1132-ND
SOLDER NO-CLEAN .025" 23AWG 1LB
SOLDER
123.61
$123.61
6
SMDSWLF.020 4OZ-ND
SLD WIRE NO-CLEAN 96.5/3/.5 4OZ.
$21.75
$21.75
Subtotal
$316.35
Shipping
unknown
Estimated Sales Tax
$19.77
Total
unknown
Step 14: Order Printed Circuit Boards From China
Picture of Order Printed Circuit Boards From China
Here are the details of the PCB order.
This is from Golden Phonix PCB  -- they have 'quick quotes' here.
This is the manufacturer used by the SparkFun company BatchPCB -- they are good for small orders especially if you are ordering multiple designs.
Step 15: To Buy One Now...
A few people have asked about buying this, the Kickstarter project is over.  I thought I would try selling them right in the instructable... but that didn't work.
So, here is link that goes to a webpage, that only has the paypal button to buy the kits.
https://sites.google.com/site/shopmarcnow/
You can get either the Blinky Fish Kit alone, the FishBowl "Fish Out of Water" kit alone, or get both.  Shipping is $2.  If you are not in the USA.... I'm not sure what will happen....
Each kit is to make ONE thing (the kickstarter rewards included parts to make a whole bunch, that is why the price here is a little lower)
About This Instructable
4,899views
8favorites
License:
Bio: Married to Domestic_Engineer (but I call her Meghan).
More by marc.cryan:Kitchen Sink - From AmazonCheapest, Bestest computer around, in beginning of 2015Cryan Family Gothic Green House
Add instructable to:
