Tiny Terrors Block Trigger Sniper Rifle/shotgun
110
Published
Introduction: Tiny Terrors Block Trigger Sniper Rifle/shotgun
About: I like to make knex guns, swords, and medieval artillery, I sometimes draw, play music, and Mod nerf guns.
Pic 1: stock
Pic 2: gun
Pic 3: scope
Pic 4: fully assembled
I'm sorry that this is a block trigger, But for me it's almost impossible to make a true trigger, So no true trigger guns anytime soon.
Can be shotgun if you put in 3 green rods.
Step 1: Bullet
Super easy.
Step 2: Stock(purely for Quicker Reload and Better Look)
Build from da picture if you can
Step 3: Scope(optional)
Easy. You don't need broken pieces I just broke my white connectors.
Step 4: Barrel
The main barrel. not too complicated
Step 5: Handle
Build 3 of these
Step 6: Barrel + Handle
Putting barrel and handle together.
Handle goes on the part of red rod that's left on the barrel
Step 7: Handle + Stock Attacher Thingy
Handle plus the stock attachment point(2 blue rods on lower handle)
Step 8: Barrel + Scope
Use the blue rod on bottom of scope to attach to the orange connector(not the block trigger)
Step 9: Handle + Stock
Attaching stock to stock attachment point
I personally put it on the back facing down instead of up, makes it easier to sight, and it's more comfortable.
Step 10: Ram Rod
So ez M8
Step 11: Inserting Ram Rod and Elastics
Inserting ram rod and adding rubber bands, The amount of rubber bands = amount of power
Pic 1: insert ram into barrel
Pic 2: put elastic on front and over scope
Step 12: Firing
Pull the ramrod back and put bullet in barrel then move block trigger out of way of ram to fire!
    • Pets Challenge
      Pets Challenge
    • Clocks Contest
      Clocks Contest
    • Planter Challenge
      Planter Challenge
    3 Comments
    mechanism flies auto with over two rubber bands unless you tape and/or glue the orange connector to the red rod
    I can make mods and * out not auto
