Introduction: Blogger to WordPress Migration: Entering the Wonderland
Everyone wants to be a part of something greater. And it’s so true while speaking about website management. Initially, you are just running a single page blog, you are absorbing into this procedure up to the hill and then, you realize that this virtual life becomes the sustainable part of your genesis. Frequently, the starting point of website timeline begins with Blogger. This is a blog publishing platform owned by Google Inc. It provides you with the simple and plain website management options like posting, editing, deleting. You shouldn’t be tech savvy or have some experience to handle this software.
Also, if you are wondering about the new pace of events,expand your website functionality, and get more site followers, there’s a way of importing your website from Blogger to WordPress.
Step 1: What Are WordPress Privileges Upon Blogger?
Nowadays, it’s worthless to speak about WordPress majesty and popularity. Counting more than 60 millions websites running on this CMS platform, WordPress is one of the most preferred website management softwares. It comprises breeze and simple ease of use together with the flexible and rich features. Apart from posting, editing, deleting, you may easily optimize your website for search engines and in this way get many more followers you have running your blog on Blogger previously. Also, you may customize your website to your needs and requirements. All in all, WordPress might be a great substitution to start the new life of your website.
Step 2: How to Migrate Website Content From Blogger to WordPress?
At first, this may sound a little bit frightful, however, if you follow the migration guide properly, there won’t be any issues. So, where to start? Here’s the list of step-by-step actions.
Step 3: 1. Create Your New WordPress Website
The first step is to create your new WordPress website. Install it on your server, get the hosting, and choose your domain name. Note that you can’t create the new website with the same domain name, Google may understand it like the duplicate and easily ban. But, in case it’s an urgent necessity, you may install WordPress with the subfolder, for instance, http://yourwebsite.com/wordpress. So, it means that the URLs of Blogger and WordPress should be different.
Step 4: 2. Make a Reserve Copy of Blogger
If you have a huge content on Blogger platform, it will be wise to make the backup copy of your website data. You should save it on hard drive, flash USB drive or any other device.
Step 5: 3. Install Blogger to WordPress Converter Plugin
Now, coming closer to the essence of the procedure, you should install the WP plugin for your website migration. In this case, I recommend to try Blogger to WordPress Converter plugin. It allows to migrate posts, pages, tags, comments, internal links, and content images. Also, this plugin makes the transfer in a few minutes, usually, it takes 15 minutes, depending on the amount of your website data.So, first you should download the file to your PC and upload this zip file to your WordPress admin panel.
Step 6: 4. Choose Additional Migration Options
Then, you’ll be able to choose some extra options for better migration. For instance, if you have some test content on your WordPress website, you may automatedly delete this content during migration. Also, this conversion plugin may migrate your links in accordance to the rewrite rules of WP site making your links SEO-friendly. And the last, you may migrate your post pictures additionally.
Step 7: 5. Post-Migration Actions
When the transfer of your site content is completed, there are just a few steps that separate you from your active website operation. So, at first look through all the posts and pages, check out whether they were migrated correctly. After that, make sure that your website is crawlable. it’s recommended to generate the XML sitemap, in this way it will be easier for search engines bots index your website. Also, one more crucial issue is theme installation. WordPress has a huge amount of free and commercial design solutions, so more luckily, there won’t be a problem.
So, probably, that is all. If you follow all these steps, you website switching from Blogger to WordPress will be simple and flawless.
