3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Blowgun Darts
Blowgun Darts
Make a real blowgun from parts readily available in most homes!
Step 1WARNING!
This IS a weapon and it IS dangerous. The blowgun should never be pointed at another person, and be careful where you shoot it. I've had the darts ricochet back towards me several feet on occasion. Also, be careful of pricking your fingers, eyes, etc. while making the darts. Thanks.
160 comments
1-40 of 160next »
Nov 16, 2007. 6:55 AMKiNG07 says:
Yo. Your blowgun, would work for approx. less than 3m due to the short length of the pipe, and yo dont even have a mouth piece??. The mouthpiece can improve the PVC pipe by making more pressure behind the darts only if ur darts dont have space in the back (cone) part. Yarn would be a bad idea, i tell u. Try film paper. Where is your tutorial about PVC pipes? Yo shud know that PVC pipe bend at the centre thus deflecting the target????
Jul 31, 2009. 3:14 AMKryptonite says:
I guess that the maker used a fairly skinny pipe due to the width of the dart, but it would not be hard to put another layer of yarn around the outside. And for a general target-and-fun thing, you don't need specific shaped paper cone, and paper crumples. Also, due to the thickness of the pipe, the PVC pipe would not bend much.
Oct 29, 2011. 5:42 AMTheMadScientist says:
if you want, instead of yarn just stick the pin through the middle of a flat cotton round, fold it a bit as it goes in so it's even and BAM, instant cotton cone flight.
Feb 8, 2008. 4:53 PMFunkNattidelic says:
i have a pvc blowgun about 2 feet long and it shoots up to ten feet. my five foot blowgun will shoot up to one hundred feet or more ( depending on how much lung capacity you have ) i can get it to go about 70 feet.
Mar 26, 2008. 8:50 PMrandy1_21550 says:
use copper tubeing and make a mouthpiece out of epoxy and fiberglass compound
Feb 8, 2008. 4:54 PMFunkNattidelic says:
sorry, i left this out, And, it doesnt have a mouthpiece.
Jul 1, 2010. 2:03 PMrobo_directions says:
is it inner diameter or outer
Aug 20, 2010. 7:20 AMZippo1234 says:
these darts are really good for shooting around the house but they are very light weight and don't get good distance.
Nov 7, 2006. 12:45 PMclickydamir says:
Hey, can you tell me what I fire these through. Oh, and can you also tell me where I can find a good yet easy DIY Crossbow. I need to find a design for Design class at school. Don't worry, the teacher said I could make one.
Jul 31, 2009. 3:08 AMKryptonite says:
My friend and I just used two pieces of wood about a foot long each, stuck them together in a T shape and used large rubber bands as the elastic. It's not too hard, instead of looking for some one else's, just draw a cross bow on a piece of paper, simplify it and make it out of wood.
Sep 11, 2009. 6:09 PMocto137 says:
yeah, i do the same thing, but with a clothes pin to hold the the arrow like the real ones.
Sep 13, 2009. 1:50 AMKryptonite says:
We just made a trigger the other day, it's awesome.
Sep 11, 2009. 6:14 PMocto137 says:
but see, for about ten times less money and work you could make a good strong and accurate bow and arrow
Mar 2, 2007. 7:21 AMcasvandegoor says:
yeah? you only show the making of the darts?!
Jul 31, 2009. 3:33 AMKryptonite says:
Is that a problem?
Aug 5, 2009. 10:04 AMcasvandegoor says:
My appologies. I'd expected this instructable to contain instructions on how to make a blowgun. The instructable was useful.
Sep 1, 2009. 7:46 AMthe "wow shammy" says:
all you need to make a blowgun is a length of 1/2 in pvc a 1/2 in threaded female adapter and a threaded to smooth male adapter. stick the female on the pipe (cut it first) load the dart, then screw the male adapter in and blow. hope this helps ya'!
Aug 17, 2009. 11:21 PMKryptonite says:
Fair enough, blowguns are pretty straight forward anyway.
Jul 15, 2009. 4:04 PMelarmin says:
you need to use a way longer pvc pipe and add more strings
Jul 10, 2008. 10:02 PMCamisado says:
This I'ble only teaches you how to make blowdarts. You should change the name of this I'ble from ' Blowgun ' to ' Blowdart '.
Jun 8, 2009. 1:21 PMZeroHourHero says:
"about 2 feet of 1/2 inch PVC" What else are you going to use it for? To hit yourself when you're done?
Jun 9, 2009. 2:20 AMCamisado says:
Wow, you're about a year late. And does he show you how to make the PVC pipe? Oh, that's right. No.
May 8, 2007. 6:39 AMda man says:
how far and accurately will it fire?????????
May 10, 2007. 2:44 AMda man says:
please answer!!!!!!!!!!!
Nov 12, 2007. 9:56 AMich bin ein pyro says:
the distance and accuracy depends on the blowgun. short guns have more power and less accuracy. longer ones have more accuracy but less power. the sweet spot length is dependant on your lung power. i guess there is no answer to it...
May 11, 2008. 4:43 PMGibson_SG_95 says:
Actually, the longer it is, the more power and accuracy there is. Ive seen your comments all over blowgun and other gun instructables. By chance do you like projectile weapons? lol.
May 23, 2008. 5:45 AMich bin ein pyro says:
why yes i do like projectile weapons.. i even have made one myself for some odd reason, it wont let me reply to this comment, or other comments for that matter.. i have a spear gun (shoots chopsticks) a 5 rubber band slingshot (paper darts) and a bow and arrow (arrows but its too small for me now) and a .22 from my grandpa about the blowgun, i agree with you. longer blowguns will get more power but require more breath power. a 2 ft. blowgun would be halfway powerful because you would release the dart at the maximum velocity of your breath. compared to a 7 foot blowgun(which would be unlogical) it would release the dart at the end of your breath. since (homemade) darts are not exactly airtight, you lose a portion of air on getting it to the end....unless you have an air compressor for a lung it is oppisate with guns because they are more airtight and have less of a barrel to go through. by shortening the barrel you would get less friction on the barrel, resulting in more velocity. hence the sawed-off shotgun. pyro-
Feb 26, 2009. 8:36 PMZetheros says:
a 7' blowgun actually is logical. Natives used to use 12' blowguns made from reeds and bamboo. I usually use my 7' blowgun for killing rats in my backyard. I use 1' bamboo skewers attached to paper cones covered in regular clear tape, glued together with gorilla wood glue. The rat becomes staked to the ground and dies rather quickly.
I found a site which a person does the same thing that I do. http://www.geocities.com/blowgunhunter/
Nov 12, 2008. 6:58 PMAnarchistAsian says:
that is a common mis-conception...
sawed off shot guns offer no gain in power.
in fact, they cause a decrease in power.
the only reason they even exist is that people wanted more compact guns, not more powerful guns...
Feb 26, 2009. 8:39 PMZetheros says:
Sawed-off shotguns also offer increased width of destruction. The pellets are spread in a larger range and deals more widespead damage when used. It also provides excellent cover fire I should think.
Feb 27, 2009. 3:15 PMAnarchistAsian says:
well that's just spread, on some shotguns you can just adjust it and uhh... shotguns are pretty much never used as cover fire, because cove fire is just shooting a TON of rounds randomly at the enemy, making them stay down so you can move to a better position. usually they use full auto, belt-fed guns...
Jul 31, 2009. 4:03 AMKryptonite says:
I've seen one sawed off shot gun in action, and the kick from it sprained the guy's wrist. (He'd never used one before.)
Jul 31, 2009. 2:35 PMAnarchistAsian says:
did it have a stock?
Aug 2, 2009. 12:54 AMKryptonite says:
Yeah, but he was holding it at waist height with one hand above the the barrel to reduce the kick.
Aug 2, 2009. 5:00 PMAnarchistAsian says:
That's a pretty stupid thing to do...
Aug 2, 2009. 11:23 PMKryptonite says:
Well yeah, he had a shot gun that he didn't want... so... well, you know how it finishes.
Aug 3, 2009. 11:10 AMAnarchistAsian says:
yeah, haha
Jul 11, 2008. 10:58 AMBeans says:
i have been shooting my whole life the friction does not matter much at all its the grain of the bullet and the load of powder ... longer the barrel the more accurate unless you go impractically long the velocity wouldn't change that much ... with a saw-off you loose distance
Mar 26, 2008. 8:47 PMrandy1_21550 says:
with a 48" blowgun you should be able to go 250 feet with a velocity at barrel of 350 you should be able to drive the pin threw a 1/4" piece of plywood at 25' easily
1-40 of 160next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:Cheeseduck
