I dug up some capacitors in the basement and decided to hook all of them up in parallel and see what happens when I short them out through different objects.
Stupid you might say, and it is. I'll probibly die of eletricution someday if not today....
Remove these ads by
Signing UpStep 1What happens when you hook it up to 0.7 pencil?
I saw in Popular Science that if you run low voltage and high current through carbon graphite rods, you will create a very intense light, that could possibly blind you if your not wearing welding goggles.
I tried it out with 0.7 pencil led and it was SUPER COOL~.
First the by-products in the led burst on fire, and then the whole piece was glowing intense red, and it seemed to sharpend the end of the led. Later I can product insanely intense light that is brighter than a camera flash with the sharpened end!
Please post more stupid or crazy ideas I should try.
what whode happen if i user 2.5v 120F caps??(yes 120F caps!!!)
is it will be strong like this to?
*runs off to connect the led to a 9v with a switch, and package it all up like a gun*
And I thought 5 photoflash capacitors was dangerous/fun enough! Where did you even GET caps that big from?!?!?
just put aluminum foil and the ground is, well, ground
well, i remebered they pass high or low voltage but high amperage thru metals to make a magnet
it literally fragmented.
bring these things up to full power, you've got 500 joules there (equivalent to a hearty defibrillator)
