Blu-Ray Laser Phaser!
Step 3Extract The Blu-Ray Diode...
If you saw my Laser Flashlight Hack Instructable than the extraction is about the same. The blu-ray diode is pretty easy to locate. There are 2 screws to remove and a small ribbon cable that needs to be cut off. After you have removed the laser mount, you need to scrap away the remaining glue and using a small jewelers screwdriver, GENTLY (I mean gently) tap around the EDGE of the diode housing to free it from the mount.
3 comments
Jul 5, 2010. 1:08 PMAdrien says:
I've got the diode housing to the 2nd picture that you're showing here, but I'm at a loss on how to extract the diode itself. I don't want to use brute force and ruin it, especially if all that's required is a little finesse
Jul 7, 2010. 3:42 AMsixgunz says:
I used pliers to bend the bottom housing away from the top at the right angle, then used a soldering iron to desolder the tags shown in the big pic above. It takes a while, but the end result is fairly clean.
Jun 13, 2009. 8:58 PMnomooremr.niceguy says:
I was just wondering, which laser is more powerful, a blu/violet laser from an HD DVD player, or a red/green laser from a dvd burner? Basically I want to know, if this project creates a more powerful laser, or does the minimag flashlight mod create a more powerful laser?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
2341
Author:Kipkay(Kipkay Videos)
Tinkerer, hackster and prankster. Hit me up on Facebook: http://www.facebook.com/kipkayvideos/ Thanks for checking out my Instructables!
