Click here to see more PICTURES and a VIDEO of the Blue Bawls LED light
Here is a new schematic that allows for a On/Off/Auto switch
Remove these ads by
Signing UpStep 1Gather the parts
We need to drop 5.6 volts at 30mA. So 5.6 / 0.030 = 186 ohms.
In this circuit he is running the LED with a 470 ohm resistor... so let's do that math...
5.6 volts / 470 ohms = 0.012 mA approx...
so he is running the light at about 1/3 brightness.
If you connected 30 LEDs in parallel, that would be 12ma X 12 or .360mA... 360mA total.
5.6 / .360 = 15 ohm resistor.
And the 9v battery would last 1/30 as long.
Another trick... to not need the resistor... if one LED uses 3.4v... then when connected in series... 4 of them would use about 10 volts. So connect 4 of them in series... call that 'module 1' then connect 9 modules in parallel... and you have 4x9 or 36 LEDs.
But again it is going to last 1/36 as long.
Reference: Ohms Law - http://en.wikipedia.org/wiki/Ohm%27s_law
This is very well written:
http://www.instructables.com/id/LEDs-for-Beginners/
Hope that helps.
Jerry
The system works fine in natural light (morning and noon)
At night, when I use neon light or other non-natural light, the led is *always* ON. What I should do in this situation?
http://i32.tinypic.com/2jbs6iw.jpg
Sorry
I Don't know.
I just have tried the demo only.
of coz it depends on your photocell supply voltage and the LED working voltage range.
