Blue LED mouse
Blue LED mouse
Tired of that standard red light under your mouse? Switch it out!
all you need is a soldering iron (and preferably a desoldering tool as well), a multimeter, and the color led you want (and possibly a resistor).
I used a cheap $10 Ativa brand mouse from Office Depot, and a blue led (3.4V 8000mcd).
This particular LED will NOT be available at your local radio shack, I specially order a batch a while back since it is a low voltage blue LED. (and quite bright too)
You can use any color of LED you want, as long as the rated voltage is 4V or lower and the luminosity is around 4000 - 8000 mcd.
I've recently (Mar-5-08) put a UV LED in a cheap HP mouse I got a while back to mod. After overriding the resistor, the mouse pumps out the 5 volts require to blast the 3.4v led. It needs a small resistor, as it frequently starts to overheat and will stop responding for a few seconds.
Kinda strange, though it makes since with UV light, the mouse works fine as long as it's not on a black surface.
As any kid who's fooled around with a blacklight will know, black objects barely show up if at all. Naturally, the light is not reflected to the eye, and the mouse is blind on very dark surfaces.
Step 1Disassembly
Disassembly
unscrew the top panel from the base.
The screws are usually hidden under the mouse's "feet", or those little black pads.
Once they're out, there may be a locking tab you have to push to pry the panel off.
If you get a cheap mouse, the inner components will be nice and big and easy to work with. the fancy ones will have capacitors and resistors that measure about 2mm x 4mm x 1mm. Those are not fun to place and re-solder.
39 comments
Nov 24, 2010. 2:05 PMzikicamiskovic says:
did the blue led work like red or?
Oct 19, 2011. 7:44 AMOllus says:
today i did this mod with white led i got from a flashlight cigarette lighter :) it is more precise, but it has to be flat on white surface. Blue and violet (not UV) work the best though :-)
Mar 24, 2011. 6:59 PMjtc10512 says:
LOL did this to match the color scheme of my computer and i didnt even see this instructable before I did it. I just ripped a spare blue LED from an LED christmas light set i had.
Jun 27, 2010. 1:12 AMMavamaarten says:
I tried this with an infrared LED, and it worked :) It looks like the mouse is dead, but it still works ... Sooo kewl :D
Jun 23, 2010. 8:55 PMzim_256 says:
The mouse sensor is a CMOS sensor and it works best with red and infrared light. If you change the led to another color, you are really decreasing the sensitivity and accuracy of your mouse. Also if you use some of the "high brightness" LED's, you're over-saturating the sensor with extra light and again decreasing the performance in the worst case, the best case will be that the mouse sensor has an automatic feedback circuit to control the light the sensor receives and if you put a really bright led, the control will reduce the brightness to avoid saturating the sensor, so the led will be no brighter than the stock led.
Jul 21, 2009. 6:42 PMBriguy9 says:
I have one of those IR mice. It has the same thing on the bottom as a red LED, but it's in a little hole and it's tiny, and no light coming from it. Also, it works like the best mouse i've ever had. Another thing: It's wireless!
Jul 21, 2009. 6:44 PMBriguy9 says:
Actually I just looked at it and if you look at from the perfect angle you can see a tiiny red led pulsating on and off at about 6 times per second.
Dec 17, 2009. 7:30 PMlilpepsikraker says:
That's not IR you are seeing. Look through your digital camera/cell phone camera, you should see the IR light being emitted, as cameras can "see" IR light.
Jul 17, 2009. 1:56 PMjunits15 says:
wouldn't it be cool to use a UV led? I think that would be awsome especially if you put it on a UV sensitive mousepad!
Jun 13, 2009. 4:22 PMgeeklord says:
If all the LED's in the spectrum work fine, I'm geussing that companies choose red, because it is the cheapest. Green and Red are cheaper than Blue an White.
Jun 12, 2008. 3:35 PMNetReaper says:
So if red works great and blue works ehh, than green should be fine because it's a middle wavelength. Right?
Jan 19, 2009. 8:44 PMguribe94 says:
any led will work because all the light is doing is allowing the camera on the bottom of the mouse to see so any color you want will work it has nothing to do with wavelengths
Jan 1, 2009. 8:21 AMbennielava says:
Green works. Tried it with success.
Sep 2, 2008. 6:54 AMTechnoled says:
Here is the Blue Optical LED Mouse site where you can modify your USB mouse or buy a blue one : Blue LED Mouse
Jul 18, 2008. 10:18 AMRedgerr says:
lol i never even thought of changing out the led. lol, i might actually do this one before i get a new mouse if im not lazy and dont get the parts, thanks for putting this idea into my head lol
Jul 6, 2008. 12:01 PMZaione says:
Well i'm now a proud owner of microsoft mouse with a white led of 6V while the red one only uses a 5V so I think I did wel there XD
thx,
lol it gives the feeling to be more accurate =S
Jun 23, 2008. 7:14 AMalex_verity says:
Great instructable i decided to try it out my led required no added resistors it is smaller than the original but it works fine.
[IMG]http://i233.photobucket.com/albums/ee97/alex_verity/Photo019.jpg[/IMG]
Mar 20, 2008. 9:59 PMthevadj says:
Would one of the multi-color LED work? You could have an every color mouse
Jun 12, 2008. 3:32 PMNetReaper says:
ya, i saw one of those on Amazon. Thats a great idea!
May 15, 2008. 7:47 PMgb78 says:
I just did it to an old USB mouse after reading this instructable (very nice, BTW). It looks cool, but now it doesn't move the cursor when over my desk as it used to, thou works very well over light blue and orange surfaces. I have other optical mice which work over the same desk (a gray-like white), and that got me very curious. I didn't override the 100ohm resistor feeding the led, and the bright seems just the same as the previous red led. I believe this is more about wavelength than amount of light, but anyway, anyone got any clue?
Feb 12, 2008. 3:47 PMYerboogieman says:
what if its a 3v LED?
Feb 6, 2008. 3:56 PMGorillazMiko says:
What if I use a higher than 4v voltage blue LED, but add in a higher resistor?
Jan 29, 2008. 12:09 AMjonny_s says:
great idea, and I was excited to see that someone else had the Altoids tin mouse idea as well, I made one a while back. It may soon become a blue LED Altoids mouse...
Jan 28, 2008. 11:01 PMrichms says:
I did this and it became really sensitive to what surface the mouse was on. i used a variable resistor inplace of the stock one and no adjustment of the brightness was as universally good as the stock red led. I then put in an infra red LED like a remote uses - now there is no visable glow at all. I like that more because the flash across the wall when you pick up and reposition the mouse is really annoying at night time.
Jan 28, 2008. 8:58 PMLinuxH4x0r says:
Cool! I got the same mouse and did the same thing, but i took it out. I'm going to pack in a few more red ones later. Nice job!
Jan 28, 2008. 3:08 PMkillerjackalope says:
I'll happily test the UV leds I have some here off a USB hub mouse mat thingy... I'll post the result... if it takes any extra work other wise just use your as base...
Jan 28, 2008. 5:06 PMkillerjackalope says:
I used the led to try and make the mouse move by illuminating with it and i worked so I'll do the hack at some point this week and see if it lives, they're good high powered ones the same diameter as the original whic helps...
Jan 28, 2008. 3:24 PM!Andrew_Modder! says:
i did this once. it broke my mouse, like it just did not move right and it lagged. but i think i didnt use a high enouf powered LED ( i just got a random blue one from radio-shack.)
Jan 28, 2008. 3:24 PMGorillazMiko says:
WOW! Amazing Instructable! It looks great, and I like the Altoids tin with the Curious George on it. My mouse isn't the see through kind, but the scroller has a red light, so I'll try to make it blue. Awesome Instructable! +1 rating. (added to favorites)
Jan 28, 2008. 2:10 PMdarth2o says:
I actually think that optical mice are at optimum efficiency with red LED's. Does it still work?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:DeLorean4905
