3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Blue Screen of Death batch
Make the blue screen of death a shortcut on desktop and disguise it or make it a screen saver.
Step 1Make the batch file
I made a batch file to imitate the blue screen, just copy and paste this to notepad and save it as bluescreen.bat
@echo offcd /clscolor 17echo A problem has been detected and Windows has been shut down to prevent damageecho to your computer.echo.echo The problem seems to be caused by the following file: SPCMDCON.SYSecho.echo PAGE_FAULT_IN_NONPAGED_AREAecho.echo If this is the first time you've seen this stop error screen,echo restart your computer. If this screen appears again, followecho these steps:echo.echo Check to make sure any new hardware or software is properly installed.echo If this is a new installation, ask your hardware or software manufacturerecho for any Windows updates you might need.echo.echo If problems continue, disable or remove any newly installed hardwareecho or software. Disable BIOS memory options such as caching or shadowing.echo If you need to use Safe Mode to remove or disable components, restartecho your computer, press F8 to select Advanced Startup Options, and thenecho select Safe Mode.echo.echo Technical information:echo.echo *** STOP: 0x00000050 (0xFD3094C2,0x00000001,0xFBFE7617,0x00000000)echo.echo.echo ***  SPCMDCON.SYS - Address FBFE7617 base at FBFE5000, DateStamp 3d6dd67cpause >nulclsecho Downloading viruses . . .ping localhost -n 5 >nuldir /spause >nul
74 comments
1-40 of 74next »
Feb 15, 2012. 4:13 AMnishnosh says:
I think this is better:@echo off
echo ^^^Microsoft Windows^
echo.
echo ^echo applicationname="BSOD"
echo version="1.0"
echo maximizebutton="no"
echo minimizebutton="no"
echo sysmenu="no"
echo Caption="no"
echo windowstate="maximize"/^>
echo.
echo ^^
echo ^
echo ^
A problem has been detected and windows has been shutdown to prevent damage to your computer.^
echo.
echo ^
DRIVER_IRQL_NOT_LES_OR_EQUAL^
echo.
echo ^
If this is the first time you've seen this stop error screen, restart your computer, If this screen appears again, follow these steps:^
echo.
echo ^
Check to make sure any new hardware or software is properly installed. If this is a new installation, ask your hardware or software manufacturer for any windows updates you might need.^
echo.
echo ^
If problems continue, disable or remove any newly installed hardware or software. Disable BIOS memory options such as caching or shadowing. If you need to use Safe Mode to remove or disable components, restart your computer, press F8 to select Advanced Startup Options, and then select Safe Mode.^
echo.
echo ^
Technical information:^
echo.
echo ^
*** STOP: 0x00D1 ^(0x00C,0x002,0x00,0xF86B5A89^)^
echo.
echo.
echo ^
*** gv3.sys - Address F86B5A89 base at F86B5000, DateStamp 3dd9919eb^
echo.
echo ^
Beginning dump of physical memory^
echo ^
Physical memory dump complete.^
echo ^
Contact your system administrator or technical support group for further assistance.^
echo.
echo.
echo ^
echo ^
echo.
echo ^
Mar 4, 2010. 2:58 PMBusterboy426 says:
it wont let me paste
Feb 4, 2011. 8:45 AMHackerzAdmin says:
you can paste on notepad not cmd
Oct 27, 2011. 9:23 PMjuiceboxplus420 says:
you can paste in both just click with the mouse to paste in cmd instead of Ctrl+V
Mar 4, 2011. 5:49 PMfabsy333 says:
Hey i made a Windows 95 bsod!!!!!!!!!!!!!!!!!!!!!!!!!!!
Copy and paste the following:
@echo off
color 1f
:9
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo Windows
echo.
echo A fatal exception 0E has occurred at 0020 : C8011E36 in UXD
echo A0010E36. The current application will be termenated.
echo.
echo.
echo * Press any key to terminate the application.
echo * Press CTRL + ALT + DEL again to restart your computer. You will
echo lose any unsaved information in all applications.
echo.
echo Press any key to continue _
ping localhost -n 2.20>nul
cls
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo Windows
echo.
echo.
echo.
echo.
cls
goto 9
Feb 4, 2011. 8:16 AMHackerzAdmin says:
what is damageecho?
Jun 4, 2008. 8:36 PMCameronSS says:
I was bored one day when I had access to Photoshop...This was when I was first learning, and it was done in about fifteen minutes (including finding source images), so pardon the quality.
Nov 24, 2010. 10:45 PMmessmaker says:
hahahahahahahahaha thats awesome!
they'll ring bill gates.
"Dude, apollo 11 has like BSoD bro! hook a brother up with some gnarley anti virus faw shaw homie"
bill gates: "dude, its windows."
Aug 24, 2008. 1:09 PMFuture filmaker says:
lol I wonder what would go through a pilots head if that showed up on all of the screens.. good job
Jun 30, 2009. 8:24 PMSuperBatch says:
OMG THE PLANE GOT BSODED! ABORT ABORT ABORT!!!
Mar 25, 2009. 3:33 PMfwjs28 says:
try this.... clicky
Jun 30, 2009. 8:22 PMSuperBatch says:
AHHHH!!!! THE EVIL CLICKY! (that you used 999,999,999,999,999,999,999,999,999,999, 999,999,999,999,999,999,999,999,999,999, 999,999,999,999,999,999,999,999,999,999, 999,999,999,999,999,999,999,999,999,999, 999,999,999,999,999,999,999,999,999,999, 999,999,999,999,999,999,999,999,999,999, 999,999,999,999,999,999,999,999,999,99 million times.
Sep 18, 2010. 2:51 PMwill421 says:
*facepalm* No he used it 999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999 million times. >_>
Jul 11, 2010. 3:42 PMellisgeek says:
Here is my version of the bsod
<code>
@echo off
cd /
cls
color 17
echo.
echo The problem seems to be caused by the following file: SYSTEM32.DLL
echo.
echo.
echo If this is the first time you've seen this stop error screen, echo restart your computer. If this screen appears again, follow
echo these steps:
echo.
echo.
echo.
echo.
echo.
echo.
echo *** SYSTEM32.DLL - Address FBFE7617 base at FBFE5000, DateStamp 3d6dd67c
pause > nul
cls e
cho Downloading virus database. . .
ping vdb.avg.com -n 1
echo Download complete. . .
echo Scanning computer for viruses. . .
echo press y to continue
pause > nul
cls
dir /s
echo.
echo.
echo.
echo.
echo.
echo Scan Complete. . .
echo Press space to see results
pause > nul
cls
echo Results:
echo No Virus Found
pause > nul
</code>
this version displays a fult in system32.dll and then scans for viruses. hope u like it
to use copy every thing between the code tags in to a file called bsod.bat
Mar 4, 2010. 2:32 PMBusterboy426 says:
wtf??!?!?! it dosnt work
May 1, 2010. 9:31 AMWindows Xp Tourials says:
To Make It Full Screen, Make A Shortcut Of It Then Right Click>Properties And Click Options And Selcet Full Screen. Then Goto Colors And Set Pop-up
And Screen Text Wight And Pop-up And Screen Backround Blue. Then Apply
And Check It Out. Note: This Dosent Work On Vista
Jan 8, 2010. 5:12 AMbillycoffman20 says:
it wont work at all
Jan 17, 2010. 7:01 PMVick Jr says:
Same here. It starts a command prompt window, but it closes almost instantly and does nothing.
I'm sure i copied the text correctly.
Although this did inspire me to make an abort shutdown shortcut; very usefull when people try to remote-shutdown me. : )
Jan 24, 2010. 2:09 AMvorlock says:
you have to space out all the words for it to work, below is his code but spaced out (This works).
@echo off
cd /cls
color 17
echo.
echo.
echo.
echo these steps:
echo.
echo.
echo.
echo.
echo.
echo.
pause >nul
cls
dir /s
pause >nul
May 1, 2010. 1:12 AMdawsonj says:
 cool, thanks : )
Mar 24, 2009. 10:26 PMmineral-2 says:
Lol I done it on my brothers computer and were did you get the wallpaper?
Mar 4, 2010. 2:42 PMBusterboy426 says:
just go to google and type in images of "Halo" or some thing
Jan 23, 2010. 6:02 PMrkr says:
Yeah... this doesn't work... it just shows a command prompt window and closes instantly.
Jan 23, 2010. 6:05 PMrkr says:
And wtf is that thing at the end about 'downloading viruses'?
May 12, 2009. 8:43 AMBogdanV says:
To make it real full-screen (ALT+ENTER), you could instead of going to Layout, go to Options->Display Options and check Full Screen. This should make it cover the entire screen without the window border appearing.
Nov 24, 2009. 9:18 PMmr.break_it says:
the window will appear on vista but its translucent so only a trained eye will catch it
Jul 9, 2009. 4:26 PMkobimaru says:
My system does not support fullscreen for CMD.
Jul 15, 2008. 8:16 PMlivesteamfan says:
How do I get it to say "Downloading viruses" and have it show all the files under the other stuff?
Nov 24, 2009. 9:17 PMmr.break_it says:
insert an "echo" command like this [echo downloading viruses] whereever you want that text to appear. on the next line, type [ cd /d c:\ ] without the brackets. next line is tree, which lists every folder in the c drive.  the code should look like this:
echo Downloading Viruses...
cd /d c:\
tree
Jul 9, 2009. 4:35 PMkobimaru says:
press "F8". The button for safe mode.
Jul 1, 2009. 10:15 PMerikals says:
Really good, I'll try this at school and see whether the IT guy can figure out what's wrong... Thanks
Jun 4, 2008. 10:59 PMDELETED_spoonty says:
(removed by author or community request)
Jun 30, 2009. 8:25 PMSuperBatch says:
Millons of `em.
Jun 5, 2008. 4:50 AMPKM says:
I'm not sure these even count as script kiddies- script kiddies at least do something other than use user-mode features and often cause some sort of damage to systems by "hacking" them. This is the computer equivalent of putting plastic wrap over the toilet seat, and I think there needs to be a word for this phenomenon, other than "irritating pranks". Beyond that, perhaps there needs to be a section of the site where all the "fake virus omg lololol" 'tibles can be put, along with the knex guns :) or an end user script that hides anything with the words "fake virus", "computer pranks" etc. in them.
Jun 7, 2008. 2:32 PMcwid says:
yeah they need to make a place for all the repeated crap on here, like k'nex guns and laptop stands
Jun 5, 2008. 1:39 AMerror32 says:
Sadly it seems that lately Instructables has seen a lot of this sort of crap appearing. Is there anyone that can explain to me how this could be useful or educational. Because this is just 12 y/o 3V1L H4x0rzzz internet pollution...
Sep 28, 2009. 5:28 PMcdousley says:
i hate knex guns
Sep 4, 2008. 5:28 PMhoWmAnyTiMeS says:
hey script kiddies... lol
1-40 of 74next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:the guardians
