Step 4Extend the length of the earphone wires
Use wire cutters to cut the wires. Cut a small two-conductor wire extension. Use the wire strippers to remove a small bit of insulation from the wires. Solder in the extension and wrap with electrical tape or heat shrink tubing.
You might also take this opportunity to loosen up the hold of the USB port. Do this by taking your knife of small screwdriver and bending up the tab on the top of the USB port. This will reduce the amount of force necessary to plug and unplug the USB charger.
Add Comment
