Step 6Expose the USB port for charging the headset
Take the end of the wire coming through your access panel opening and pass it through an opening in the USB port and twist the wire back on itself. The idea is to make a firm mechanical connection so that you can draw the USB port firmly against the inside of the skin of the banana at the point where the port will be exposed.
Use your X-Acto knife to trim the opening to fit the USB port. Carefully apply some epoxy glue to secure the USB port into place. Be sure not to get epoxy in the USB connector itself.
Apply epoxy glue to the other end of the headset circuit board to anchor the board in place at both ends.
Cut and remove the draw wire after the epoxy has set.
Add Comment
