Step 7Create button on outside of banana
The flashing of the blue LED on the banana is impressive and goes a long way to reinforcing the idea that the banana really is a Bluetooth device.
I was lucky enough to have on hand some translucent tubing that was perfect for channeling the light and serving as a rod to actuate the button on the circuit board. The tubing is from the stick of a sucker that was part of a Valentine's Day bouquet of candy flowers I received from my wife.
Using your paper template of the printed circuit board, try to figure out where the switch and LED are underneath the skin of the banana. Use your knife and drill bit to make hole above the switch. Cut the tubing to the necessary length and insert it into the hole.
Honestly, I have a hard time actuating the switch using the tubing, so answering the phone by pushing the button is difficult. If you can find a way to keep the tubing on the switch, you may have better luck. Perhaps a dab of silicone glue would do the trick.
comment
Add Comment
Add Comment
