Bluetooth Based Home Automation
7,687
102
13
Posted
Introduction: Bluetooth Based Home Automation
This project presents the overall design of Home Automation System (HAS) with low cost and wireless remote control. This system is designed to assist and provide support in order to fulfill the needs of elderly and disabled in home. Also, the smart home concept in the system improves the standard living at home. The project was earlier built using IC P89v51RD2 (8051 series).The IC was configured using bluetooth module HC05. The Software of Flash Magic was used to program the IC and the home automation process used the app BlueTerm .However the use of above mentioned IC requires an external programing hardware which was not readily available. Hence we used Arduino uno which is easily programmable and configurable. In our project the main control system implements wireless Bluetooth technology to provide remote access from smart phone. The system intended to control the operation of fan in house with relatively low cost design, user friendly interface and ease of installation.
Keywords:
1. HC05
2. Arduino Uno
3. L293D
4. Smart Phone
5. BlueTerm App
Step 1: Components Required
1x Arduino Uno
1x Bluetooth Module (for example: HC-05)
1x Smartphone (any Android will work)
BlueTerm application
1x L293D IC
1x DC motor(12 volts)
1x Breadboard
Jumper Cables
Step 2: Bluetooth Connections and Modes
Command mode:
1. Key is now connected to 3.3v,
2. Now remove the Vcc pin of Bluetooth and reinsert it.
3. Now you can see an orange led glowing slowly which indicates that bluetooth is in command mode.
4. Now your HC05 module will respond to all the AT commands.
5. Now set the baud rate 38400 and open the terminal(Using flash magic terminal here).
6. Using AT commands set username and password
Data mode:
1. Keep the key pin open.
2. Now restart the Bluetooth.
3 Orange led blinks fast ie the bluetooth is in data mode.
4. Now when bluetooth is connected to the app red led blinks.
Step 3: Circuit Diagram
connect the circuit as per the diagram
Step 4: Arduino Code
refer the code
run it in Arduino IDE
Step 5: App
download app from
https://play.google.com/store/apps/details?id=es.p...
The
Inputs given from the app:
’0′ – Turns off the DC motor
’1′ – DC motor rotates to right
’2′ – DC motor rotates to left
Step 6: Report
engineers im attaching report for this circuit
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
12 Comments
How many inputs we can give?
(Means how many task can be done?)
Only one at a time
can i use the HC-06 module
Yes but the ports will change
Good project!
Do you know of a replacement for the BlueTerm application that will work on a iPhone? Thanks
No sorry will let you know asap
This looks interesting. It's an Apple Store App so it was well vetted by Apple for any know problems. The UI is very clean and overall a nice looking App. I will see how well it works with my project and report back. Thanks NivebhaB for the followup.
Thank you for the good tutorial. :)
