Introduction: Arduino Bluetooth Rc Car
Picture of Arduino Bluetooth Rc Car
this is my first Arduino project it is quite simple to make .
it will take about half an hour to make it it's quite simple as you think
you can also make it by following steps given below and make have fun it's give me create joy when I finally made it .
now it's your turn to make it.
just follow the steps given under description
Step 1: Requirements
Picture of Requirements
Arduino uno board
Bluetooth module hc 05
4wd shield (adafruit)
Jumper wires
Two 9v battery (1. arduino board
2. external power supply to sheild )
Battery cap with 9v pin jack
Step 2: Connection
Picture of Connection
mount the shield on arduino board and connect Bluetooth to the audino or directly to the shield by soldering on it connect RX to TX ,TX to RX ,ground to ground ,vcc to vcc as shown in the figure and also connect Motors to M1 (left) and M2 (right)
Step 3: Coding
//*** 1- Documentation
//This program is used to control a robot car using a app that communicates with Arduino trough a bluetooth module
#include
//creates two objects to control the terminal 3 and 4 of motor shield
AF_DCMotor motor1(3);
AF_DCMotor motor2(4);
char command;
void setup()
Serial.begin(9600); //Set the baud rate to your Bluetooth module.
void loop(){
if(Serial.available() > 0){
command = Serial.read();
Stop(); //initialize with motors stoped
//Change pin mode only if new command is different from previous.
//Serial.println(command);
switch(command){
case 'F':
forward();
break;
case 'B':
back();
break;
case 'L':
left();
break;
case 'R':
right();
break;
void forward()
motor1.setSpeed(255); //Define maximum velocity
motor1.run(FORWARD); //rotate the motor clockwise
motor2.setSpeed(255); //Define maximum velocity
motor2.run(FORWARD); //rotate the motor clockwise
void back()
motor1.run(BACKWARD); //rotate the motor counterclockwise
motor2.run(BACKWARD); //rotate the motor counterclockwise
void left()
motor2.setSpeed(0);
motor2.run(RELEASE); //turn motor2 off
void right()
motor1.setSpeed(0);
motor1.run(RELEASE); //turn motor1 off
void Stop()
motor1.setSpeed(0);
motor2.run(RELEASE); //turn motor1 off
motor2.setSpeed(0);
Step 4: Uploading
remove Bluetooth module before uploading the codes
Step 5: Power Supply
Picture of Power Supply
connect 9 volt battery to arduino board and you can also connect 9 volt battery to shield through external power to increase power supply to your Motors
remove the power jumper shown in the figure.
Step 6: Install App
Picture of Install App
install Bluetooth RC controller app through play store
open the app
it ask for permission turn on Bluetooth allow it
the first time password is 1234 or 0000
then click on gear shown in the app now "choose connect to car"
the red button blinking in the app turn to green
now you are connected to your car play with it and enjoy your project.
thank you for watching this instruction
ms5728 (author)2017-11-13
Hi sir. Can u help me to edit the same bluetooth control car with arduino by adding
1. ultrasonic sensor as sense the obstacle
2. 2 leds green when forward
3. 2 leds red when reverse
4. Siren by using buzzer
5. 1 led stop yellow
ms5728 made it! (author)2017-11-13
Hi sir.
Can u add ultrasonic sensor in the same project and the same program. I just made 100% program same as yours and kindly pls help me to add ultrasonic sensors. Plsssss sir help me
supniz (author)2017-03-31
Hi, I am getting a lot of code errors, could you please help
C:\Users\user\Documents\Arduino\libraries\arduino_723047\src\Temboo.cpp: In member function 'int TembooChoreo::run(IPAddress, uint16_t, uint16_t)':
C:\Users\user\Documents\Arduino\libraries\arduino_723047\src\Temboo.cpp:281:52: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
if (!m_client.findUntil("HTTP/1.", HTTP_EOL)) {
C:\Users\user\Documents\Arduino\libraries\arduino_723047\src\Temboo.cpp:301:62: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
if (m_client.findUntil("x-temboo-time:", HTTP_EOH)) {
C:\Users\user\AppData\Local\Temp\ccqB0Z6e.ltrans0.ltrans.o: In function `__static_initialization_and_destruction_0':
C:\Users\user\Documents\BTcar\CarCode/CarCode.ino:6: undefined reference to `AF_DCMotor::AF_DCMotor(unsigned char, unsigned char)'
C:\Users\user\Documents\BTcar\CarCode/CarCode.ino:7: undefined reference to `AF_DCMotor::AF_DCMotor(unsigned char, unsigned char)'
C:\Users\user\AppData\Local\Temp\ccqB0Z6e.ltrans0.ltrans.o: In function `Stop':
C:\Users\user\Documents\BTcar\CarCode/CarCode.ino:73: undefined reference to `AF_DCMotor::setSpeed(unsigned char)'
C:\Users\user\Documents\BTcar\CarCode/CarCode.ino:74: undefined reference to `AF_DCMotor::run(unsigned char)'
C:\Users\user\Documents\BTcar\CarCode/CarCode.ino:75: undefined reference to `AF_DCMotor::setSpeed(unsigned char)'
C:\Users\user\Documents\BTcar\CarCode/CarCode.ino:76: undefined reference to `AF_DCMotor::run(unsigned char)'
shaileshY3 (author)supniz2017-04-15
and remove the Bluetooth module before uploading the code
maybe you should first install AFmotor library. it is easy To get through adafruit official site.
marlonss (author)2017-02-15
Thanks for posting. Will save me time trying to figure it out.
shaileshY3 (author)marlonss2017-02-15
my pleasure my dear friend.
MuhammadA950 (author)2017-02-14
it will be work or not ?
cause my car is not working
shaileshY3 (author)MuhammadA9502017-02-15
definitely it will works if you follow the instructions properly.
AryanD6 (author)2017-02-14
Can you tell the use of the shield and the connections bit more in detail also can this be made without the shield??
shaileshY3 (author)AryanD62017-02-15
if you using the shield I mentioned then you just mount pin to pin right mentioned on arduino and the shield it is quite easy to use.
shaileshY3 (author)2017-02-13
thanks for appreciating me??
thanks for appreciating me ??
About This Instructable
3,366views
31favorites
License:
More by shaileshY3:Arduino Bluetooth Rc Car
Add instructable to:
