Introduction: Bluetooth Control Robot
Picture of Bluetooth Control Robot
This is very easy to make and cheap robot you can get all the component on amazon and the app and sketch from playstore
Step 1: Component Needed
Picture of Component Needed
1.) 2 DC Geared Motors +Wheels (Bought it from amazon Rs.190)
2.)Chasis (From Amazon Rs.115)
3.)L293D IC Based DC Motor Control Board ( Amazon Rs.100)
4.) Caster Wheel (Amazon Rs.85)
5.)Battery bank (As per your power requirement I used 11000Ah cause i want to play more)(From flipkart Rs 650)
6.)Arduino UNO Board( You can use any board .I used Arduino Uno ) (From Amazon Rs 450)
7.)HC 05 Bluetooth Module(Amazon Rs.190)
8.)Jumper Wires Soldering Iron
9.) Arduino Bluetooth Control App from playstore (Because it is free and the amker also provide link to download the sketch which will work with the app. I have also uploaded the sketch with this instructable,Its just a modified version of the original sketch
Step 2: Connection
1.)Connect motor and caster wheel with the chasis
2.)Solder the jumper wires with motor (just take care of the polarity)
3.)Connect the motors to the motor control board (you will recognize automatically when you see the board its easy)
4.)Make a USB connector to give main supply to the board (Just cut you spare USB cables ,take care of the polarity)
5.)Now connect Motor control Board to arduino Uno (Refer the Pic)
Arduino Board
A1 -- 4
A2 -- 5
B1 -- 6
B2 -- 7
VCC- 5V
GND- GND
You can use other pins also accordingly you have to change the Sketch
6.)Connect Bluetooth Modue HC 05 to Arduino (Refer the Pic) (Do these connection after uploding sketch only or the sketch will not upload)
HC 05 Arduino
TX RX
RX TX
VCC 3.3V
GND GND
Step 3: Sketch and Other Details
1.)Upload the sketch to the board
2.)Download arduino bluetooth control on your mobile
Now In the app
Device 1 ON Motor 1 FWD
Device 2 ON Motor 1 Backward
Device 3 ON Motor 2 Fwd
Device 4 ON Motor 2 Backward
So for Fwd Movement Device 1 and 3 ON Other OFF
For Backward Movement Device 2 and 4 ON Other OFF
Like wise left and right
This is the best free app i got on play store and since Am not an app developer i am just using it
you can search for more apps or can modify the sketch for better control
In the next Instructable i will tell you how to connect the robot to internet so that you can control it from anywhere (Thats why i haven't done much research on Bluetooth app and sketch)
Video for internet controlled robot controlled via website (Will upload the instructions shortly)
EdwardF2005 (author)2017-06-01
does this work with IOS and iPhones
Harshits20 (author)EdwardF20052017-06-04
The app I used is for Android only. However you can get similar app on iOS also
However if you want to control it via internet then yes it works on iOS also as control will be from a webpge
EdwardF2005 (author)Harshits202017-06-04
Thanks!
AkashS95 (author)2016-05-26
can i got ur program.
Harshits20 (author)AkashS952016-05-30
program is already attached with this instructable
mohitmaurya175 (author)2016-04-01
Can you send me the link for arduino programming
sketch is with this instructable
Can use 12 volts battery with gear motor
can you send me the link of arduino programming
the motors i have used are rated for 9v only .If you want to use 12 V battery then use a voltage regulator IC 7809 to step down the voltage to 9v then supply to motor or use 12V rated motors
Arduino Uno can be powered with 12 V so there is no problem . if you are using other board like nano or pro mini then with 12 V battery use IC 7805 for 5v step down
Alok Shaw (author)2016-03-07
The powerbank has output voltage of 5V , then how you used it for running both the motors and the Arduino board ?
i have tried a dc-dc boost for 12v but it supplied only 60mA...
Harshits20 (author)Alok Shaw2016-03-07
use a high power dc booster. available on amazon
XL6009 DC-DC step up module, better than LM2577, with adjustable booster power supply module, Output Max Current 4A
Alok Shaw (author)Harshits202016-03-07
thank for the held !!
Alok Shaw (author)Alok Shaw2016-03-07
*help
arduino runs on 5v and in the power bank i have 2 ouputs. 5v 1a. and 5v 2.1 amp always give motors seperate supply and not through arduino board
I used 100rpm 9v geared motor and its not a speed bot its a utility bot. so faced no problem in running with 5v
BrooklineLocksmith (author)2016-03-02
Congrat super
wold630 (author)2016-02-29
Can't wait for the next instructable!
About This Instructable
6,397views
105favorites
License:
Bio: love tinkering with arduino ,hardware programming ,have made home automation for my complete home running on solar power
More by Harshits20:Internet Controlled house and Robot(Home Automation)Bluetooth Control Robot
Add instructable to:
