Bluetooth Controlled Power Outlets ( Using Arduino )
6,873
54
Published
Introduction: Bluetooth Controlled Power Outlets ( Using Arduino )
You can control power outlets with your phone with the help of Arduino.
simply plug whatever you want to control in one of the outlets and use your smartphone to turn it ON/OFF
Step 1: You Need :
1- Arduino
2- Bluetooth Module
3- Relay Module
4- Power Adapter (For Arduino)
5- ON/OFF Switch (Optional)
6- Wires
7- Outlets
Step 2: Schematic :
Follow the schematics above to make the connections
Step 3: Code :
char val;
#define RELAY1 8
#define RELAY2 9
void setup()
pinMode(RELAY1, OUTPUT);
pinMode(RELAY2, OUTPUT);
Serial.begin(9600);
void loop() {
if( Serial.available() )
val = Serial.read();
switch (val) {
case 'F':
digitalWrite(RELAY1,LOW);
break;
case 'B':
digitalWrite(RELAY1,HIGH);
break;
case 'L':
digitalWrite(RELAY2,LOW);
break;
case 'R':
digitalWrite(RELAY2,HIGH);
break;
Step 4: Test
The code was written specifically for this app
https://play.google.com/store/apps/details?id=brau...
If you use another app make sure to change the values in the code to meet the app values
If you have any questions leave a comment below :D
    • Casting Contest
      Casting Contest
    • Clocks Contest
      Clocks Contest
    • Woodworking Contest
      Woodworking Contest
    2 Comments
    what are the specifications of all components used in the project
    i want to use 6 power outlets and AdruDroid aap...plz help me out what changes i had to make?
