Introduction: Bluetooth Controlled Robot
About: Hi , I am a Maker-Space Educator .I love to design thing and make things using tools like electronics,papercraft,3d printing,etc.which are parts of makerspace.
hi
i am ajay i would tell you how to make your own app as well as your mobile app in a very easy way.
so i will first tell you how to make your own app
Step 1: How to Make a Bluetooth Control Robot App Using Mit App Inventor 2
hi
To make your own app you just need a gmail address to log in and follow the video i have connected
shortcut: you can download from gallary ,search"robogear " app in mit gallary app.
Step 2: Part Require to Make It.
hi
the parts you require is
1.arduino
2.l293d
3.pcb
4 ic 7805
5 hc 05
6 1000uf/25v capacitor
7 4pc bo2 dc motor+wheel
8 foam sheet
9 soldering iron
10 drilling machine
Step 3: The Whole Process How You Will Make It.
hi
here is a video how you can make the whole robot.
Step 4: The Arduino Code
hi
i am pasting the whole code here you can copy and paste in your arudino .
if motor is moving reverse just change the pin no in first 4 lines of code.
------------------------------------------------------------x---------------------------------------------------------------
#define LMP 2
#define LMN 4
#define RMP 7
#define RMN 5
int firstSensor = 0; // first analog sensor
int secondSensor = 0; // second analog sensor
int thirdSensor = 0; // digital sensor
int inByte = 0; // incoming serial byte
char BYTE;
boolean status_unlock;
boolean status_bluetooth;
long interval = 1000; // interval at which to blink (milliseconds)
long previousMillis = 0; // will store last time LED was update
int minite,sec;
void setup()
// start serial port at 9600 bps:
Serial.begin(9600);
//pinMode(2, INPUT); // digital sensor is on digital pin 2
establishContact(); // send a byte to establish contact until receiver responds
pinMode(LMP, OUTPUT);
pinMode(LMN, OUTPUT);
pinMode(RMP, OUTPUT);
pinMode(RMN, OUTPUT);
digitalWrite(LMP, LOW); // switch off MOTOR
digitalWrite(LMN, LOW); // switch off MOTOR
digitalWrite(RMP, LOW); // switch off MOTOR
digitalWrite(RMN, LOW); // switch off MOTOR
status_bluetooth = true;
status_unlock = false;
sec = 0;
void loop()
if (Serial.available() > 0)
inByte = Serial.read(); // get incoming byte:
if(inByte == 'A')
digitalWrite(LMP, HIGH);
digitalWrite(RMP, HIGH);
inByte = 0;
if(inByte == 'B')
digitalWrite(LMN, HIGH);
digitalWrite(RMN, HIGH);
inByte = 0;
if(inByte == 'D')
inByte = 0;
if(inByte == 'C')
Serial.print('D', BYTE);
inByte = 0;
if(inByte == 'E')
Serial.print('E', BYTE);
inByte = 0;
if(inByte == 'G')
inByte = 0;
if(inByte == 'F'){
Serial.print('G', BYTE);
inByte = 0;
if(inByte == 'S'){
Serial.print('S', BYTE); // send a char
sec = 0;
} // if(Serial
unsigned long currentMillis = millis();
if(currentMillis - previousMillis > interval) {
previousMillis = currentMillis; // save the last time you blinked the LED
sec++;
if(status_unlock==true){
if(sec== 11){
digitalWrite(LED_PIN1, HIGH); // switch on LED
delay(800);
digitalWrite(LED_PIN1, LOW); // switch off LED
sec = 0;
else sec = 0;
} //Loop
void establishContact() {
while (Serial.available() <= 0) {
Serial.print('.', BYTE); // send a capital A
delay(500);
