Shown below are the bluetooth adaptor before and after modification.
Remove these ads by
Signing UpStep 1Dismantle!
Get some wire-cutters, on one piece of plastic, cut along the red lines, as shown below. On the second, cut the corners off so it looks like the second picture.
Piece the whole lot back together, and it should look somewhat like the last picture (Red being what it was before, Black being what is is now.)
I didn't find any glue on mine, it just split open when pried.
As for the class, I am not sure what it is.. I just got it to pair with my desktop..
The antenna is the metal bit on the PCB that is covered by the case. This is visible in step one, picture one (the topmost part, not the four USB connectors)
I hope this is helpful.. I am sure there is an 'ible for bluetooth reception alteration that you could follow.
Cheers.
Will.
I was using what I had lying around, so foam, model (polystyrene) glue, Lego bricks and a hacksaw, were all easily available components.
If you cut most of the plastic out of the case (of the dongle) and used hot glue, you could make it able to be used a a lego brick. Otherwise the case is too low for the brick to attach.
My Instructables are mere ideas, my methord of doing it. Be creative. Create your own way. [:]|-[
Thanks much for the comment on the case size issue. With hot-glue or silicone you could do the press-mold, but I couldn't quite tell from the pictures that the space was so tight.
Again, a very cool little project, and well presented!
And really nice instructions ...
