Introduction: Bluetooth Controlled Robot
Picture of Bluetooth Controlled Robot
controlling a basic robot using a Bluetooth enabled mobile
Step 1: Materials Needed
Picture of Materials Needed
1. Bread board
2. HC-05 Bluetooth module
3. jumper wires or breadboard wires
4. Induino R3 or any arduino clone
5. two 500 rpm motor
6. two 9v batteries
7. L293D
8. Chassis
9. Wheels
10. Android mobile
you can buy chassis, wheels, motors as per your budget....
Step 2: Breadboard Connection
Picture of Breadboard Connection
connect the breadboard in this way way so that 5v flows through the outer side and gnd through the inner horizontal connection. connect the 5v and gnd to the breadboard from the induino.
The applied 5v should pass in this order ABCD
Step 3: Connecting HC-05
Picture of Connecting HC-05
connect the Vcc to 5v and gnd to ground... connect the rx of hc-05 to the tx of the induino and connect the tx of the hc-05 to the rx of the induino... key and state need not be connected.
Step 4: L293D
Picture of L293D
connect the pins 4,5,12,13 of L293D to ground and connect O1, O2 to left motor, similarly O3,O4 to right motor,
i1-pin2 of induino
i2-pin4 of induino
i3-pin12 of induino
i4-pin11 of induino
Step 5: Motor Connections
Picture of Motor Connections
after connecting motor it will look like this...
if you want connect a buzzer to pin8 of induino which will act as horn...
Step 6: Code
upload this code to induino....
Step 7: Connecting With Bluetooth
Picture of Connecting With Bluetooth
Arduino Bluetooth RC Car
Download this app from play store..
connect a 9v battery to induino.. the Bluetooth module will start to blink continuously.... now open the app in your mobile
1.At first a red light will blink at the left top of the app
2. go to options and click connect
3. connect to the Bluetooth device.... default pin is 1234 or 0000
4. after connecting there will be green light in the left top corner of the app
that's it now you can enjoy your own Bluetooth RC robot
there may be some mistakes.. tell me if you find any ^_^
DXGJyothish (author)2017-03-18
Is it possible to add camera and ultrasonic sensors to it?
varun96 (author)DXGJyothish2017-05-18
yes
karthikeyan 007 (author)2017-03-26
thank sir
thank you sir
What happens if we use 300rpm motor
ShashiP13 (author)2017-02-10
Do I have to buy a motor driver too??
Sir I had bought Arduino Uno r3.....Will it work???
varun96 (author)ShashiP132017-02-10
Yes
SuhasA3 (author)2016-09-12
Sir,
Can I code this For Arduino uno
souravguragai (author)SuhasA32016-12-04
Yes you Can
SuhasA3 (author)souravguragai2016-12-05
Thnx sir
TAPAN KRISHS (author)2016-03-03
Is it possible to control cardboard robot in the link
https://www.instructables.com/id/Cardboard-Robot/?A...
with bluetooth using your procedure(only forward and backward direction).
varun96 (author)TAPAN KRISHS2016-03-03
Yes you can with few minor alterations in the code...
hasmilazlan (author)2015-03-26
it can use voice?
varun96 (author)hasmilazlan2015-03-30
Yes
jc25000 (author)2014-12-17
i don t want that information. i wish know how you program bluetooth with java for android. so i wish look at the code of file *.java pls
varun96 (author)jc250002014-12-17
sorry i dont have that :(
is it possible to see the android code ?
I downloaded it from play store....
goto settings and you can see these
About This Instructable
10,378views
24favorites
License:
Bio: Love robotics
More by varun96:Programming AT89S52 Using USBasp ISP ProgrammerEasiest Way to Bootload Arduino UnoLine Follower without microcontroller
Add instructable to:
