Here's what you need:
- 1 inch thick foam board insulation (for this project, I actually prefer the cheaper white stuff. I like the way it come apart, tears, etc. The amount and size you need depends on how many windows you want to "board up")
- A serrated knife of some sort (a regular steak knife can do the trick)
- A flat head screwdriver or similar tipped item
- Mouse sander (optional)
- Brown latex paint (if you have a paint sprayer, it will make this a lot easier because you need to reach lots of nooks and crannies)
- Gray latex paint (A cheap paint brush is used with this)
- Hot glue (double sided duct tape or velcro could also be used)
- Duct tape (regular or double sided)
- tape measure
Remove these ads by
Signing UpStep 1Take some measurements
The other boards that will be attached to the diagonal board don't necessarily need to go past the window. As you can see in the first picture, some do and some don't. This gives the appearance that some of the boards may have broken or whoever put them up just used whatever they had laying around.
4
comments
Add Comment
LAWNMUSIC (author)
says:
scoochmaroo
says:
Add Comment
