Boarding Ladder for Sailboat
2,634
7
Published
Introduction: Boarding Ladder for Sailboat
I needed a sturdy, stable ladder suitable for climbing aboard a sailboat after going SCUBA diving - basically I would be coming out of the water carrying about 60 pounds of lead weights, air tank and equipment. The ladder has to extend a couple of feet into the water, not move in use or fold up, and not corrode in salt water.
This is the second version of the design. The first was made of plywood, which broke, and used brass screws to secure the treads, which corroded the aluminium through galvanic action. This one is made of solid mahogany with nylon bolts to secure the treads.
The ladder has a U-shaped notch at the top to fit over the boat rail. The top is reinforced with a horizontal member, glued and bolted with stainless-steel bolts.
The treads are aluminium tubing fitted into holes drilled in the uprights, secured with epoxy and with nylon bolts which prevent the tube sliding out of the hole. Pure aluminium is chemically active but has a passivating oxide layer which renders it  resistant to corrosion. In contact with less active metals such as steel or brass in salt water an electrochemical potential is created which etches away the aluminium. So I chose non-conducting nylon.
There are pieces of nylon set into the inside of the upright, secured with recessed stainless steel screws. These prevent the ladder from rubbing on the GRP boat hull and scratching it.
The ladder has been in service many years, works well and is still in excellent condition. The only drawback is that when climbing with bare feet, the narrow treads are a bit uncomfortable.
    • Water Contest
      Water Contest
    • Oil Contest
      Oil Contest
    • Creative Misuse Contest
    2 Discussions
    Where do you store the ladder when you're not using it?
    great idea...heres mine made out of plywood and hardwood for the treads. glued airnailed and screwed with stainless steal screws, then "varnished" with poly resin. note how it was cut to the profile of my deck and hull, with incorperated "stand-offs" to keep it vertical
