Boat Repair with Carbon Fiber
 by schkip1973
Featured
This instructible is to show you how to make small repairs to watercraft eg. cracks or chips on kayaks, surfskis, surfboards etc.
If you have ever paddled or lifted a kayak across rocks like these, you will probably need to do a repair.
This 'ible will work for:
- small wooden boats or kayaks
- fiberglass or carbon kayaks/skis/surfboards
- repairs where the hull is intact and not compromised
- scratches and small cracks
This ible will not work for:
- rotomolded or 'tupperware' kayaks - the epoxy will not bond to this material
- some kayaks which have single-part + hardener finish / old gelcoats
- boat repairs which are structural in nature. One piece of tape will not repair a hole in the hull :)
- high performance craft below-the-waterline hull repairs.  This repair will create too much drag.  Time for a new boat!
If in doubt, check with a marine engineer for a survey before commencing work. Another option is to try a small patch of the boat (eg. under the seat thwarts on a rowboat) to check the part bonds well.
If you are in luck, this low cost repair will save you the cost of a new boat and extend the lifetime of your vessel by many years to come.
Step 1: Safety First!
Safety First!
This instructible using the following things that are dangerous to humans with short and long exposure.
Some Hazards:
Epoxy Vapours: the epoxy resin gives of vapours which are toxic.  Wear a respirator with a gas canister at all times you are working with epoxy.
Epoxy Sensitivity: epoxy resin can cause sensitisation in people with time.  Avoid contact with skin and follow the manufacturer's safety instructions.
Epoxy splashes: avoid the wet epoxy touching your body - especially be careful around your eyes (considering this is a mask). Wear safety glasses and gloves.  People may have an allergy to latex gloves too! In which case you can use the non-latex gloves or thin allergy free gloves.
Carbon Dust: when you grind away the finished carbon fiber shape there will be carbon dust.  Wash it down and away, and wear a particulate or dust filtering respirator / cartridge when you are doing this step.
Carbon Slivers: Avoid getting small bits of carbon 'tow' or splinters caught in your fingers.  Again gloves are good here.
Paint fumes: when spraying work in a well-ventilated area and wear glasses/gloves and old clothes, not your tuxedo.
Scared Away? I hope not!
Cambronze says: Jan 24, 2012. 9:00 PM
I also rub petroleum jelly (vaseline) into my hands and forearms. This seems to help with the fibre irritation.
aristide202 in reply to CambronzeFeb 5, 2012. 11:08 AM
Before or after the work? It's not easy to get rid of dense vaseline from skin so tell us.
schkip1973 (author) says: Jan 26, 2012. 6:20 PM
thanks for the info!
I like the idea about the 'mantra' .. makes it like an instinct rather than something that is forgotten.
StephenMiller1958 says: Jan 25, 2012. 2:53 AM
Thanks for emphasising the safety angle. All commercial products are safe if used correctly.
You get good at safety by treating the steps like a mantra.... don't be impatient - recite to yourself the safety steps for example:
To change a drill bit.
- wait for the drill to stop spinning
- disconnect the power
- deploy the chuck
-put the old drill bit it it's proper place
- attach the new drill bit
-return the chuck to its proper place
- reconnect the power
- test the drill with a quick squeeze
This is the approach that medical staff use in responding to a cardiac arrest - like robots reciting their mantra of their role on the cardiac cart...
Probably I would have added never work alone... have someone nearby - even if only through the kitchen window - watching your back....
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
