Boffer Armaments Pt. 2: Great Axe
Introduction: Boffer Armaments Pt. 2: Great Axe
Like any good Viking or Dwarf; if you have a big shield, you need a big axe. So, here's part 2 of our little mayhem making.
For this, we'll make a double bit axe modeled somewhat after Gimli's axe from Lord of the Rings. Why? It's good, solid and heavy.
The tricky part was making a heavy axe while balancing it with sufficient padding to not cause someone damage. With this, you'll feel the hit, but it will be something like getting hit by a Jotun's memory foam mattress rather than a heavy hammer.
You will need:
A haft (PVC with poplar dowel core left over from a previous endeavor)
A core (1/2" rubber sheet)
Padding (more neoprene-like foam)
Fasteners (Hockey Skate lace, bolts and contact cement)
Step 1: Cutting the Core
The core is what will give the axe's bit its shape. Thick rubber is a good way to maintain flexibility and shape, especially if you fold it in such a way that it helps add strength. For this, I took a 14"x14" sheet of 1/2" rubber and cut out sections to allow for folding over the haft.
For this I used a band saw after having tried an Xacto knife and a box cutter, neither of which gave great results. So, I took a fine-tooth band saw blade and slowly cut my way through it, ending with the shape below.
I then drilled a hole through rubber, and a corresponding hole through the center of the haft (not quite center, since cylinders are difficult to drill through and attached it with a pretty decent bolt and washers.
Step 2: Shaping the Core
The core is pretty simple of a design, and holds its shape through 3 bolts. One to attach it to the haft, and two to keep the bits from flapping apart. They are far enough back, and covered in enough foam that even getting hit by the broad side of the head won't cause much damage.
The biggest trick is finding the correct size bolts to push all the way through, but not to tighten past the size of the nut on the other end. However, you also need them to go all the way through fairly springy rubber. A combination of elbow grease, a hex driver on a power drill and some uncouth vocabulary was able to finish this part, and you end up with the core/skeleton of the axe head.
Step 3: Aesthetics
To make the head of the axe a little better shaped, I took some of the cutouts from the first step and attached them to the bottom of what would have been the blades using smaller bolts. Doing this gave it more of the impression of a bearded axe rather than a hatchet.
Step 4: Foaming the Head
To add a little more strength, I wrapped the head of the axe in hockey laces so that it cuts back on some of the give since I only attached it with one bolt. The laces help keep the head from turning to an angle when it hits something.
Since I had a very large neoprene-like foam tube to work with, I created the first sheath for the core out of one piece of that. The axe head fits snugly in and it gives the head a little more meat without a lot more weight.
To keep it from moving around, I "stitched" the foam around the head of the axe. Using something like hockey laces makes it have a lot of surface area to keep from tearing the foam. You can either drill holes in the foam to thread it through, or try and find something to use as an awl. I tried both; the awl is just slightly less messy.
I used two separate laces, one for each bit, so they laced together and tied around the head for added security.
For all tests, it did not move, including a full-swing on the shield.
Step 5: Foaming the Blade
The blade is a lot simpler to foam. I cut one of the medium sizes of neoprene-like foam down one side and contact cemented the inside of the medium foam, and the outside of the foam already making up the head.
This gives it a double-thickness, and also keeps the stitching from moving around too much.
As a little more reinforcement, adding a wrap or two of heavy duct tape or gaff tape will keep it together a bit better.
Final weight: 6.6 lbs
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    Any metal in a boffer seems like a bad idea. I would recommend punching two smaller holes in your core side by side and use a zip tie to secure the two halves. Who knows, you may have tried that in the past though and it didn't hold up well.
    I, for one, would like to see more boffer instructables. They can be a lot of fun and I'm glad people are putting them out there!
    If I had teflon or nylon bolts, I would've used those. However, I tested them out on myself first at full swing and you can't even feel the metal through all the padding.
    I have tried the zip ties before, and I've only found a way to make them work well for adding hilts and stuff around hilts. Having them go through the foam always makes the foam tear really quickly for me.
    I keep adding them under Nerf and suggesting Boffer as a subcategory for something.
    Best of luck!
