3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Boffer Dagger
Boffer Dagger
This instructable will show you step-by-step how to make a simple boffer dagger using common supplies quickly and cheaply.
This lesson is based on that on which I learned, and some experimental methods and ideas. Thanks to my LARPing friends at SUNY Purchase for helping me learn a safe way for making good boffers.
Step 1The Materials
In order to make our dagger boffer, we will need some supplies:
1) 1/2 inch PVC pipe. This will act as the core to provide support for the foam padding, and our hilt. This generally costs $2 - $4 for a 10 foot piece, higher depending on the quality. (check the PSI on the piece, the higher the number, the more durable, but lower grade does just fine for this project. The piece should be cut down to the size we need, which will be about 14 inches.
2. Duct tape. The color preference is up to you, The cost depends on where you go. Online websites tend to have the best deals, with larger roles costing about $3.25 per role of 1 in x 60 yards, to about $6.25 for 2 in x 60 yards (preferable) on tapebrothers.com. Of course, online stores like tapebrothers.com have a WIDE assortment of colors too, making them more appealing. Of course, hardware stores like ACE have a decent selection, but the roles tend to be more expensive. Look in large flea markets, sometimes god deals do come from there too, but I digress.
3. Pool Noodle. This makes up the foam padding for our boffer. You can find them at stores like poolcenter.com for about $3 for 60 inches (5 feet) of foam. I recommend poolcenter.com for this. Note however that it must have the hole down the center.
4. Electrical tape. This will be used to add grip to our hilt (handle) Depending on store, prices will vary. I once again reccoment tapebrothers.com, you can get the rainbow pack - 10 rolls of electrical tape (red, purple, blue, orange, yelow, green, white, gray, black, brown) for around $10 ($9.80 + shipping) here: http://www.tapebrothers.com/Electrical-Tape-Rainbow-Pack-p/el766clrain.htm
5. Open cell foam. Yellow, usually lightweight. This will be used to create thrusting tips, or soft squishy ends of the boffer designed for using the end of a boffer to thrust safely. For this, you have a lot of places you can turn to. Old chairs, couches, eggcrate are just three places you can find some, scavenging doesn't hurt it is all the same, and if you can't scavenge, you can buy reasonably large quantities cheaply.
6. Scissors for cutting tape when needed.
7. Knife, or switchblade for cutting the pool noodle.
YOU MIGHT BE ASKING: Why use PVC and pool noodle? For one, it is a lot cheaper than pipe foam and graphite kite spar, and secondly, for those who don't know how to properly wield a boffer, the heavier PVC boffers are good for learning how to control your swings..
14 comments
Apr 4, 2009. 10:43 AMBrother_D says:
You've got the idea right, but those weapons are ugly! Take some pride in your handiwork and pretty it up! If there are some pieces of tape lifting up, tape around until they're flat. Stuff like that can make a big difference. Also, when building these, don't rush, these look very thrown together. Whenever you tape the blade, do so carefully and gently. Keep having fun though!
Apr 4, 2009. 5:11 PMBrother_D says:
I'd really like to see that claymore. And sorry if you took offense to that first sentence, I didn't mean to be mean. It's really hard to express tone on the internet. If they ever get that right, I'll never leave my computer.
Sep 26, 2009. 7:04 PMcorey_caffeine says:
check out my spear it's amtgard legal and very nice
Jun 2, 2009. 5:03 PMBrother_D says:
Awesome.
Jan 18, 2009. 7:43 PMWurdBendur says:
I wouldn't want to get hit with any of those weapons, but I suppose you pull your hits. Still, your taping is pretty terrible. And might I suggest using a cloth cover instead? If you really must have a metallic finish (and I know this is typical), you can get a metallic fabric. Sew it into a sock-like tube and pull it over the end. Then just tape it at the bottom or add a draw string for easy removal. In Dagorhir, we fight full-contact, and our weapons can last for many years with this design. Of course, we also use better foam (i.e. blue camping pads). Or at least take a little more care with your tape. There's a guy on YouTube (search for boffer tutorials) who does a Mormon battle game (lol, I know). He will show you how to do it correctly.
Jan 20, 2009. 12:41 AMWurdBendur says:
Most of the camping foam used by Dagrohir members is made by the same company, so that kind of variation isn't an issue. Some people like to spend even more on different foams that work better and last longer, or have whatever different properties they're looking for. But pool noodles just can't survive the kind of stress we put on them. They are regularly torn apart by kids in swimming pools, and burly men swinging them at full force are just going to destroy them. Camping pads, on the other hand, are actually hard to tear up. Noodles can certainly work just as well if the construction is good - they just start out softer (whereas the blue pad foam takes some time to get broken in) and won't last that long because the foam (whatever kind it is) is not as durable as the stuff used to make camping pads. So you're right, it's not the foam alone, but the foam you use definitely sets the upper limit on the quality and longevity of your weapon. Just as a heads up, you can head to the camping section of your local everything-store and pick up a roll of foam for six something. This will make about three swords. Also, most LARP groups like round swords so that all sides are safe, but we Dagorhirrim like to have edges, so ours are box shaped. Foam in the form of a flat roll is just more conducive to this construction, which is probably the main reason there are hardly any pool noodles on the field. They're usually considered noob weapons, but surprisingly rare even then.
Mar 17, 2009. 9:49 PMWurdBendur says:
If you're using one of the really thick pool noodles, you could try taking a slice off each side to create the flats. If you're using the thin ones, just put it on normally, then split another piece in half down its length and put each half over the edges to give it that shape. I think this is how it's usually done, but maybe you could find another method. If you can, try to run a long strip up one edge, over the tip and then back down the other edge. A couple layers like that will make a very safe tip, maybe a little extra should be added if you want to stab with it, depending on how hard you use it. Also, Sculpted blades are always nice! You may also be able to file or sand the foam into interesting shapes, besides just cutting with a knife. Though since the graphite is probably thinner, cutting the noodle into sections may be necessary. You might quarter it and put one on each flat, and two or three layers on each edge.
Jan 29, 2009. 4:02 AMDuctTape Pwnage says:
i am going to make some instructables on how to make a better boffer and other larping stuff (no offense)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Travelsonic
