1. Find a FLASK (Something that won't crank due to pressure)
2. Boil water and add it to the flask
3. seal it and invert the FLASK
4. place an ice cube or two on top.
5. the condensing of the gas above the water from the ice cubes causes the water to boil
***note-after the FLASK and water cool to room temperature the heat from your hand should make it start to boil again.
Only try this under adult supervision.
epic grammar fail!
BTW How do you know it was 40C at the end? I didn't see a thermometer anywhere.
DISCLAIMER: This is a workable concept. Weather it may be functional or dangerous would depend on materials.
If you want to use a bell jar, make a base with two holes in the bottom.
Place your specimen on a raised platform as there will be a layer of water at the bottom.
Holes need valves that are good enough to hold a vacuum (or near) and everything needs to withstand 100degC.
Attach a kettle to one valve and leave both valves open.
Place your specimen. Place the bell jar over it.
Turn on the kettle. There will be a rainstorm inside as the bell jar, base, and specimen heat up. This could take a while. Eventually the amount of water trickling out of the valves should slow and there should be steam billowing out of the exit valve.
Of course at this point EVERYTHING IS HOT ENOUGH TO GIVE YOU A NASTY BURN! (including the valves) Also by this point virtually all the air should have been replaced/displaced by steam.
Now close the valves and disconnect the kettle(so it doesn't blow up) and WAIT.
As everything cools down the steam will condense and the pressure will drop.
DON'T THROW ICE OR EVEN COLD WATER ON IT!
IT WOULD ALMOST CERTAINLY EXPLODE.
Once it gets to room temp you should have a pretty good vacuum.
Personally I would use a vacuum pump, but if circumstances make this easier for you then have fun and don't kill yourself.
Gordie.
