3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Boiling a Casio G-Shock Mudman
The buttons on the Casio G-Shock Mudman series are notoriously stiff to depress, mine appear to be no exception. Several people online have said that by boiling the bezel for 20-30 minutes you can soften them up. Well I have some spare time and a digital camera handy so I'm going to see if this crazy idea works.
Note: If you do not have the correct tools for doing this I suggest you stop right here. The screws on the Mudman are very small (little buggers) and without the correct screwdrivers you stand the chance of badly stripping the heads. Also, I take *no* responsibility for you doing this at home and ruining your watch.
Step 1Getting Started
Getting Started
Getting started: This is optional. I am going to remove the straps on my Mudman to make things a little easier. I'm also going to throw them into the boiling water to see if the straps get softer after boiling.
Once the straps have been removed it makes it a little easier to handle the main body of the watch.
29 comments
Jan 29, 2009. 8:21 PMthe_mad_man says:
i have an analog watch so no buttons :P, but the other 2 (i have 3) are VERY hard to pull the little knob thing out to change the time, and i font think boiling them would be a good idea.
May 25, 2009. 6:54 AMgrt57 says:
LOL... I gave up wearing one altogether years ago ;-P~ ~
Nov 29, 2011. 2:09 AMDiabloscope says:
NEVER !!!! lol mine is almost fused to my wrist , funny how its water resistant 20 Bar=200 meters i dont wear in the shower , and goes right back on after .
Sep 26, 2009. 3:00 PMGreyGhost2 says:
Surely Cell Phones are phasing wristwatches out...or will they be combined?...but that is another Instructable.
Dec 26, 2009. 6:20 AMihsuf says:
 just got finished doing it it worked perfect at 20 minutes
Dec 20, 2008. 4:30 AMGZNG says:
this probably occurs as the heat canses the rubber to expand and enlarging the pores. the gas bubbles enter the pores making it springy, thus more comfortable... this is just a hypothesis
Nov 22, 2008. 7:53 AMecky the third says:
You say, 'you take no responsibility for ruining the watch' what about the wife's new saucepan.?? lol. ecky 3.
Nov 24, 2008. 3:35 PMbiospot says:
This is a truly unusual idea. Whoever thought to boil the rubber / plastic parts? I wonder though.. I used to have a rubber/plastic watch and after about 2 years, the plastic strap broke. Just like that. I had to have it replaced. What a pain. Do you think the boiling process would lessen the lifespan? Also.. the pictures look like it has changed color from Black to Gray after boiling.... is that right? Perhaps the same thing could be accomplished by leaving it in the sun for a few hours on a very hot day? Just curious.. and impressed....
Nov 25, 2008. 7:49 AMcsmiler says:
Leaving it in the sun will most likely create cracks in the plastic....same thing happened when i left a rubber band in my pocket for a few days.
Nov 20, 2008. 7:51 PMroosta says:
so why do they make the watches with stiff buttons to start then?
Nov 23, 2008. 11:13 AMElJefeUno says:
Since it's water resistant to 660 feet, most likely they make the buttons stiff so that they won't depress at depth if you scuba dive with the watch. When you dive with a watch the inside of the watch stays at surface pressure while the external pressure increases drastically. Soft-touch buttons could be pressed in by water pressure alone, or even break and let water into the watch. If you're a scuba diver, I don't suggest this mod!
Nov 25, 2008. 7:32 AMevad says:
I use my g-shock for diving, and I wouldn't suggest this mod either. I agree with EljfeUno. I believe WW 2 depth charges were rigged to go off at certain depths by varying the spring rate on the detonator switch. Interesting instructable, though... even if it is for the digitally (as in fingers) weak.
Nov 20, 2008. 12:35 PMCryptonat says:
Great instructable but, as a person in the Jewelry/Watch profession, I would not recommend anyone opening their watch without a trained professional. :P Most people just screw it up inside. That is a very delicate piece of equipment on your wrist.
Nov 20, 2008. 8:42 PMosgeld says:
i tend to agree with the muffinator its not a delicate machine, and its not a sonic welded 1$ gas station watch, which if you did get apart the screen would fall out, never to be realigned again its a fairly well biult digital watch, that seems to be in a module, theres not much that could go wrong, besides loosing the spring, that we are so well informed of i understand your concern, and i agree with it, im not taking apart my Bolova any time soon, but you have to keep it in prospective with the instructable :)
Nov 20, 2008. 4:17 PMT3h_Muffinator says:
Although this may be true for mechanical watches, digital watches aren't nearly as delicate - they're solid state (no moving parts). Trained professionals (at some point) had to open a watch for the first time - i'd think you should be encouraging people to explore their time-keeping devices, rather than telling them to just go to a 'trained professional'. Anyhow, sorry for ranting - I didn't mean to dishearten you if I did.
Nov 20, 2008. 7:55 PMcougarmandan says:
Its hard to believe that trained professionals hang out around here. This is the place of improvising and inventiveness. Training get in the way of all that. Myself, I had to take my G-shock anniversary gift to a trained professional to get it ruined.
Nov 21, 2008. 7:04 AMCryptonat says:
I assure you, I am not Wal-Mart employee. :P
I do see a very large number of persons who bring in their watches saying (or trying to avoid saying, and yes I do mean solid state electronic watches) that they were trying to just change their battery and messed it up. Agreed, this community is a maybe a little *wink* more skilled than the average population, but it is still sound advice for anyways to see someone who has been trained and has a living from working on watches.
Again. NOT WAL-MART. That place is pure evil. Oh, and go shop your local Mom and Pop stores. :P
Nov 20, 2008. 1:35 PMbillz260 says:
This is instructables, ruining stuff is how you learn.
Nov 21, 2008. 4:56 AMjridley says:
Well said! Nothing that's already broken anyway makes it out of my house unless I take it apart, unless I've already taken one like it apart. People ask me how I know how to fix stuff, but when I ask, they've never taken anything apart to see what's inside. They have as much curiosity as a slug.
Nov 20, 2008. 2:45 PMDavvik says:
One of the truest statements I've heard in a while.
Nov 20, 2008. 7:12 PMpuffyfluff says:
That's a clever way to soften them up!
Nov 20, 2008. 4:25 PMamarquez says:
Boiling the "Nylon" propellers that were very common many years ago in the model airplane arena, usually provided better behaviour, preventing brittle fracture in most of the "crashes" on grass, and some on hard pavement also. Maybe the wristwatch material is also nylon? amarquez in Mexico City.
Nov 18, 2008. 11:24 AMcomodore says:
Great project! I really like it! I think I am going to buy one of these watches... In the final step you saied you feel like a Mythbuster... If you like Mythbusters and watch Mythbusters, join the Mythbusters group and discus their shows, episodes and their ideas whit other fans... rate:***** +I added it to my mythbusters group
Nov 18, 2008. 7:49 AMjessyratfink says:
Such a good idea! I used to do watch repair and people always complained about the buttons and straps on those types of sport watches. I wish I would have known this back then!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
33
Author:bfgreen(Brian's Backpacking Blog)
Brian Green is an avid lightweight backpacker and author of the popular Brian's Backpacking Blog. Originally from Southampton, England, Brian has lived in the US for over 14 years, finally settling in...
more »
