Bolt Bracelet
773
15
8
Published
Introduction: Bolt Bracelet
Made from M6 x 16mm stainless hex head bolts and some M6 stainless nuts
You will require at least 10 bolts, depending on your wrist size.
4 nuts.
Welder
String
Hacksaw/grinder
Drill & drill bits (Pillar drill recommended)
Hammer & centre punch
Step 1: Drill the Holes in Bolts
Centre punch all the bolts in the middle of the threaded end.
Drilled out using a 3mm drill bit with plenty of cutting fluid.
Step 2: Clasp
Weld two nuts on the head of a bolt. I used another bolt to wind the nuts together straight and so the threads align properly. Make sure you can wind a bolt down both nuts.
I also cut the threads back in half on the bolt.
Another bolt will have a nut on as a locking nut.
Step 3: String
Tie a knot on one end and slide the Female part of the clasp on first, nut side first.
Slide all the bolts on and tie a knot the other end.
Step 4: Done
The bolt should freely spin and tighten up into the nuts. Use the locking nut to help stop the bolt coming loose.
Bracelet Challenge
Runner Up in the
Bracelet Challenge
    • Stick It! Contest
      Stick It! Contest
    • Pets Challenge
      Pets Challenge
    8 Comments
    I have drilled bolts like this before (for my 3d printer) and it can be tricky to keep the hole centered and not have it veer off especially if using a small drill bit. Putting the bolt in the chuck and holding the drill bit with vice grips helps a lot. I had doubts when I first read about the technique but after 2 failed attempts drilling a 1/8" hole trough a 1/4" bolt I tried it and it works.
    Doubles as a zombie-fighting tool during the zom-pocalypse, right? :)
    I would say use brass or stainless steel bolts/nuts to prevent rusting from sweat.
    They are stainless
    My bad, must have missed that.
    No worries!
