Introduction: Bonsai Deadwood (Jin or Shari)
Bonsai is a Japanese art form using miniature trees, but what is a Jin or Shari? No, sadly Jin is not a type of drink but instead Jin is a bare-stripped part of branch and a Shari is a barkless part of trunk of a still live tree. After seeing a few examples of what this can look like when done by a professional I had to try and make one, so this is my attempt at a fake Shari with an old branch for a brand new baby tree I got.
Step 1: Find Your Wood, Strip the Bark
First thing I did once I knew how I wanted my Bonsai to look was to find a nice piece of wood and striped the bark off. Then, if needed, shape it with a chisel.
Step 2: Apply Lime Sulfur
A Shari is typically artificially sun bleached white by using Lime Sulfur, because it seals the wood from rot and bugs without harming the living tree.
I just purchased a small bottle of Lime Sulfur from amazon and used an old paintbrush to apply it to the wood. Then I left it in the sun to dry as per instructions on the bottle. After drying the wood turns to a light white color (the camera does not do it justice)
TIP: This is sulfur and smells bad. I recommend doing this step outside
Step 3: Design
For this fake Shari, I decided to treat the red part of the wood different because I did not like the way the sulfur looked on the red wood. So anywhere it overlapped, I used a chisels to get a clean line the way I wanted the design to work.
You can do whatever you want in this step to make the wood look the way you want. If you want to use a chisel to make small designs you can do that too!
Step 4: Tung Oil
After designing how I wanted the transition from white to red look, I applied tung oil to the remaining wood that I did not put the sulfer on to really let the red portion pop! And pop it did!
Step 5: Add Your Tree!
Finally, I added it to my tree. This was a free tree that I was given on Earth Day it is still young and a little small. I tied it to the Shari in order for it to grow the way I want. After a while I will untie the tree from the wood and the tree will be able to stay in place and continue to beautifully grow around it.
Beyond the Comfort Zone Contest
Summer Fun Contest 2016
Makerspace Contest
