Book Box
5,740
224
14
Published
Introduction: Book Box
This is a Book Box made out of chip board and card stock.
Step 1: Make the Cover of Your Book Box
Cut a piece of good quality card stock to 8 x 10 3/4 inches (see photo 1 ). Cut 2 pieces of chip board to 4 x 7 inches and one piece of chip board to 11/2 x 7 inches.(seen in photo 2 )
Step 2: Attach Chip Board to Card Stock
I like to start by drawing a half inch line down one of the 8 inch sides and one of the 10 3/4 sides. This helps to keep the chip board straight . Line the first pc. of 4 x 7 chip board up to the half inch marks and glue in place. Next glue two scrap pieces of the chip board together. This will be your shim . The next piece to add is the 1 1/2 x 7 inch spine.
Line up the bottom of the spine with the half inch line , place the shim in between the two pieces of chip board for spacing ( see photo 1) , glue in place. Place shim on the other side of the spine piece and repeat with the last piece of chip board. Trim the four corners of card stock .( see photo 2 ) .You will have a half inch strip of the card stock on all four sides . Use glue or score tape to wrap the card stock on to the chip board and glue in place.
Step 3: Add Liners to the in Side
Cut two pieces of the same card stock to 3 3/4 x 6 3/4 and one piece of card stock to 1 1/2 x 6 3/4 . Glue to the inside of the cover. (shown in photo 1)
Step 4: Make the Foe Pages
Cut two pieces of card stock to 6 1/2 x 9 inches and two pieces of card stock to 3 3/4 x 9 inches. (see photo 1 )
With the 9 inch turned to the top (as seen in photo 1 ) score every 1/2 inch. Do that to all four pieces.
Accordion fold all of the 1/2 inch score marks . I like to use a clip on each end to keep the fold in place.
Take one of the 6 1/2 x 9 pieces and one of the 3 3/4 pieces and weave together to form a corner (see photo 2 ,3 and 4).Use a clip to hold in place. Do this with all pieces until it forms a rectangle
Lift the top flap ,add a dot of glue and glue flap in place. (see photo 6) Do this to the top and then the bottom corners.
Your assembled piece should look like the image in ( photo 7).
Step 5: Add the Decorative Paper and Accordion Folded Pages
Choose decorative papers and cut two pieces at 3 3/4 x 6 3/4 inch . Glue in place.
Glue the accordion piece in place, off setting it to line up to the center fold (see photo 4 )
Step 6: Add Decorative Paper to Out Side of Box
Cut 2 pieces at 3 3/4 x 6 3/4 inch and 1 piece at 1 1/2 x 6 3/4 inch for the spine glue in place {see photo 1)
Add ribbon around out side of box and tie in place (see photo 2)
Step 7: Time to Decorate !
I covered two chip board corners with gesso (see photo1 ) . When that dried I inked them with Distress Ink ( see photo 2 ). Glue the chip board corners in to place.
I took some of my favorite embellishments from my stash and glued to the cover.
Step 8: All Done !
This is my finished Book Box ! I hope you give it a try , your only limited by what you can think of :)
    • Pets Challenge
      Pets Challenge
    • Stick It! Contest
      Stick It! Contest
    14 Comments
    Thank you for your Instructable
    Nice job.
    Rima
    Amazing and impressive that you built it from scratch! Well done!
    One note I'm obliged to make: when you use the word "foe," referring to the false pages, I think you're looking for the word "faux." Yay, homophones! :)
    Thanks erosser ,
    and thanks for letting me know of the misspelling :)
    It seems easy to do. I will try for my sisters's daughters.
    I love scrapbooking and crafts gifts.
    Thanks
    Regards
    Thanks Amanda :) I do a ton of paper crafting !
    (((HUGS)))
    Deann
    I am going to make one for a baby shower to stash notes of wisdom which will also be the title. Great idea and thanks for sharing!
    Thats so awesome ! I would love to see it :)
    I will share pictures when I'm finished :-)
    What is the purpose of the book box? A secret hidden compartment?
    Yes :)
    I use them to keep bits and pieces of lace or ribbon and flowers that I craft with.
    It would be a great place for live notes :)
