DIY Book Jewelry Box
Introduction: DIY Book Jewelry Box
Make a box to stow all of your jewelry. You can store it lying down or upright. Or hide your jewelry on your bookshelf!
Step 1: Materials
You will need:
Large Book Box ( I bought mine at Michael's for $11)
Adhesive Squares
Wire (Soft, Flexible 14-8 gauge)
Box's to fit your other Jewelry (Braclets, Post earings, rings etc.)
Push Pins
Other decorations ( I bought wooden birds)
Exacto Knife
Step 2: Cut and Place the Cork
Using the Exacto Knife and a ruler to cut the Cork to fit into the back of the box. Place the adhesive squares on the cork. Depending on the size of the cork use 2 to 5 squares per piece.
Step 3: Earrings
Remove the upper layers of cork. Take the Wire and cut a piece 2-3 inches long depending on how long you want plus an extra 1/2 inch on each side. Bend the wire to 90 degree angles on both sides. Push the wire into the cork on the upper right side (this is easiest done on carpet.) Next bend the ends that sick out on the back against the cork forming a "staple." Repeat this step for 2 to 4 more pieces of wire depending on how many earrings you have.
Step 4: Necklaces
To hang necklaces use Pushpins or Hook Screw. Place them in the cork in an upper corner and layer extra adhesive squares behind if needed to secure them. Use 1 - 5 pins depending on how many necklaces you have.
Step 5: Bracelets and Other
Take the extra boxes and paint them if you want to match the color. Use adhesive squares to attach the boxes to the cork. I wanted to keep the lids as well because this prevents the jewelry from falling out if I turn the box upside down. When attaching make sure you have room for the lids as well.
Step 6: Extra Decoration
If you want any extra decoration on in your box simply add it with glue. Be careful that the placement of your decorations won't make it so that you cannot close your box.
Step 7: Finish
Place your jewelry inside and enjoy!
    • Paper Contest 2018
      Paper Contest 2018
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
    I'd love to try this with also making my own book box
    That's awesome!
    I'll have to try that myself.
    Nice job! I love this idea.
    That is such a cool idea! And you set up everything inside so nicely! Wonderfully done :)
