3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Book Lamp
Step 5Band it together
Band it together
Place the light into the book and place a rubber band around the cord and pages to keep it in place as well as keep all the pages together.
7 comments
Jul 26, 2010. 8:36 AMSyx says:
An easy way to avoid the paper getting too hot, and to increase the light output, is to line the cavity with some aluminium foil - the heat and light are all then reflected out of the book and away from the paper.
Jul 9, 2010. 6:39 PMfrogfrog47 says:
Also you could just make a fake book cover from cardboard and print, draw, or put a design on it and use more cardboard for supports. If you couldn't use a book.
Jul 9, 2010. 10:16 PMluvasu says:
I agree, but better if you can RECICLE every part of the "lightbook". Why not to "carve" in our "junk box"?. And, why not to reinforce the inside of de fakebook using the inside of a tetrabrick (aluminium foil on cardboard), adding extra brightness to the mounting?.
Jul 8, 2010. 2:55 PMmdog93 says:
i thought that, but CFLs don't get very hot, but still if it's on for long periods it could be a bit of a hazard. Should be fine though if not on for long, right fungus?
Jul 9, 2010. 2:31 AMiborgiborg says:
I like this idea and will try it. The bulb itself doesn't get hot, but, I have had one of these feel hot enough to burn. This was the plastic area where the globe ends at the bottom. Between the glass and the bulb holder in the photo above. I would only set up an LED globe.
Jul 9, 2010. 10:10 PMluvasu says:
I agree, to avoid any danger from heat, use a LED bulb or similar... always with led light.
Jul 8, 2010. 9:13 AMtomaway says:
Everything is so close together... I wonder how hot it is?
Jul 8, 2010. 5:04 PMdanceafterdark says:
You could always switch to an LED bulb. They produce much less heat, so there wouldn't be as much cause for concern.
Jul 8, 2010. 2:33 PMshinyegg says:
wondering same thing... any fires yet?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1413
Author:fungus amungus(my site)
I like to make things both useful and odd. The odd projects are usually more fun. I'm also the Content Manager here at Instructables. Follow @edabot for more
