Book Page Necklace
1,092
49
Published
Introduction: Book Page Necklace
About: I like multimedia stories and pockets.
When I ran into all these wonderful book page pendants, I knew I had to make a pendant along the same lines. I didn't want to mess around with with resin, so I turned to a recent favorite of mine: washers.
This nice little pendant is fairly easy to make and uses text from a real book. The washer part of the pendant can be removed from the wire, which makes it easy to flip the pendant around. The pendant in the pictures has text that was cut out of the scripts I used when I was in Hamlet and The Tempest.
Materials
Wire (I used gauge 20)
Two Washers (The dimensions of mine were 3/4" outer diameter, roughly 5/16" inner diameter)
A page of text
Superglue
Double sided tape
Mod Podge
Tools
Pliers
Scissors
Pencil
1. Draw a circle on the page around the two text that you want to put on your necklace. Make sure the circles are larger than the hole in the middle of the washers, but smaller than the washers themselves. Cut out the circles.
2. Stick a tiny piece of double sided tape on the back of the each circle and tape one circle to the inside of each washer. If you put the washers together, the text should end up facing out.
3. Stick the two washers together with the double sided tape pieces that were used to attach the text. Make sure that the pendant looks however you want it to look, and then surround the edges of the washers with superglue to keep them together
4. Spread a small amount of mod podge over either side of the paper part of the pendant. Wipe off any that gets on the surface of the metal. This is just to protect the paper.
5. Take a wire and wrap the middle of it tightly around the pendant, as seen in the pictures. Kink the ends of the wire (but not too sharply) when they meet, having reached full circle. Twist them together a time or two, and then wind the rest of the wire around a small, circular object to create a hole for a chain to go through. The pendant should be able to pop in and out of the wire. Bear with it, this step can be a little frustrating. I had to throw away a wire or two before I finally got it right. It'll work eventually.
    • Flowers Challenge
      Flowers Challenge
    • Spotless Contest
      Spotless Contest
    3 Comments
    As it turns out these pendants are quite handy if you need to flip a coin, too. Just realized this.
    Very clever. How heavy is the finished item? Thinking about earrings here.
    You could also vary from book pages to music pages, papercraft sheets, favourite fabric etc.
    I love the way yours highlights a specific word. I've got a very battered old dictionary awaiting craft projects that I may tailor words for certain recipients.
    Thanks! The pendant is 4.4 grams without the chain, which is 5.9. I've never worn earrings before, but I think they'd be okay weight wise. Washers also come in all different sizes, so I'm sure you'd be able to find the perfect weight.
    I love your ideas! If you make any of these, could you post pictures?
