3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Invisible Book Speakers
Create a pair of speakers by recycling six old hardback books and a pair of speakers from a broken cd player. They will be unnoticeable on a bookshelf, cost virtually nothing, and sound pretty good.
Step 1Tools and Material
Tools and Material
You will need:
6-8 hard back books, about 1 1/4 inches thick each
2 speakers, 3 inches in diameter
glue
Tools:
Hot glue gun
jigsaw
drill
paintbrush
2 or more clamps
small board
pencil
box cutter
goggles
47 comments
1-40 of 47next »
Apr 5, 2009. 6:45 PMfizban7 says:
what is this last step for?
Aug 22, 2011. 5:59 AMqwerty987 says:
could you put the wires through the big hole and save yourself a step
Jul 26, 2011. 10:04 PMnolan5683 says:
i love how the book is called "a blast of trumpets"
Jul 25, 2011. 9:44 PMhfuller says:
If you had a stereo that had separate speakers could you do this but do the stereo part with the controls and stuff like this too? It wouldnt be excaltly the same you would need to put the spines on a hinge somehow so you could open and close it :D just an idea
Jul 8, 2011. 7:40 AMSantaB says:
How loud are these? Is the output pretty good or very muffled?
May 24, 2009. 6:56 PMDoc Holliday says:
Um, couldn't the speaker point out the top of the book set instead?
That would simplify a lot of the issues discussed here, as well as the whole construction process.
Somebody would have their head hovering over the books to notice it.
May 11, 2010. 8:37 AMthecolor says:
This seems like a logical solution and while (yes) the sound would go up rather then out (for the below comment) in that case (if undesirable), why not create a brace behind the speaker held in the middle of the book hollow and mount the back of the speaker to that instead of the front.  Then, the actual cone(s) would be free for full movement (hitting nothing) and there might be a better (or worse) sound as it floats in the center of the book.
Just a thought.  Either way, I have 4 black box speakers I plan to mimic this project with but leave them in the speaker boxes for the original sound.  I think I do agree with that, if the box is built, use that, place some book sides on the left and right and a foe front.  As for the back, do you really need to place anything on it (covering wires or holes)... it's not seen (typically).
Aug 12, 2009. 2:12 PMYerboogieman says:
I have a pair of good sounding speakers that went through a flood, so i hot glued them together, perfect for this because they wouldn't be seen.
Jul 16, 2009. 6:40 PMMartRo says:
Great idea! Maybe you could use books with dark covers, so you won't see the holes at all.
Jul 15, 2009. 7:52 PMjessyratfink says:
Really well executed! I do book projects too. :D Good to see you used the crappy ones that aren't worth anything. That's a few less I'll have to buy from someone at work!
Jun 2, 2009. 4:42 AMPyroMonger says:
ADD THIS TO THE ART OF SOUND CONTEST!
Jun 1, 2009. 6:46 PMpyroninja9 says:
i made one of these for my tech class my teacher really liked it
May 21, 2009. 5:24 PMYerboogieman says:
"A blast of trumpets."
Apr 5, 2009. 10:08 AMjordanpa says:
The most positive thing I can say about this project is - To get reasonable sound, leave the speakers in their original enclosures and don't mess with them. In other words, don't do this project. If you must do this project, note that the glue used to fix the speakers must be kept away from not only the cone, but also the suspension (the flexible ring around the outside of the cone. You would need to be very careful to get this right, as the suspension is normally right next to the metal frame that you are gluing. Loudspeakers often have lugs that can be screwed. It is best to use these for fixing, thereby keeping glue away from the suspension. I don't really care if you ban me from the site. But please - take my advice first. I have actually designed and built my own quality loudspeaker enclosures and understand the technology.
May 25, 2009. 8:44 PMmodskwod says:
I can respect what you're saying, but you never know, the compacted paper might be better than the original enclosure. If the original speaker was made of plastic, yes, the paper would be better, since it won't be as resonant. I agree about the way he fixed the speaker in place though, if it were me, I'd have found a way to actually mount it somehow. BTW, the part around the cone is the surround, you probably made a typo. The suspension is the spider(s).
May 25, 2009. 12:56 PMPyroMonger says:
I know the author already replied but I wanted to get my two cents in. The point of Instructables is to share ideas and learn from eachother as a community. As for this project..I love it because it's original and unique. I don't know about you but I can confidently say I've never before seen speakers made from books....It's a new twist on a long used idea with the books. Learn to appreciate other people's work and stop criticizing. It's not always about perfection. It's the pleasure of doing the project and the satisfaction of the end product! Now go sulk in a corner and abide by the 'be nice' policy.
May 25, 2009. 12:59 PMPyroMonger says:
5/5 from me, Techno. Great ible....I'm going to try this as soon as I get some decent sized hardback books and some old speakers.
May 20, 2009. 9:24 PMMadMonso says:
If I understood correctly, just be careful not to glue the actual speaker diaphragm. I did like that you included the hole in the back but unless it's in the proper location, I doubt it will do much more that prevent muffling. Then again, with scrap speakers I doubt you'll notice a difference
May 23, 2009. 11:39 PMhahasgirl says:
it would be nice to hide the holes. Perhaps you could use books that come with a paper jacket and after making the holes attach them to the books? The sound would still be able to come through nicely but it would look more attractive.
May 24, 2009. 8:03 AMzimmemic25 says:
then it would even better to make bigger holes into the cardboard, because then the paper jacket can act like a second speaker membrane
May 22, 2009. 9:13 AMdeemerch says:
"A Blast of Trumpets"... nice choice for a book speaker thanks for sharing!
May 21, 2009. 11:03 AMqdogg says:
I think you meant safety pin instead of clothespin! I don't think a clothespin would make a hole in many things... this is a good idea.. bookshelf speakers for sure. It looks like that spade bit was left out in the rain for awhile. Another good way to drill in books is w/ a hole saw because it doesn't tear the paper as much.
May 21, 2009. 3:34 AMwetnap says:
interesting look, but probably poor engineering for speakers. walls of speakers have to be stiff as possible. i don't really see the books as being a good material to work with.
May 21, 2009. 12:00 AMomnibot says:
I luvz .. will make for my livingrooms 5.1 setup.
Mar 22, 2009. 4:20 PMlemonie says:
Book-club books? How do they sound? L
May 20, 2009. 8:52 PMsevesteen says:
If you want more bass, add a sub-woofer with a crossover. Bass is non-directional, so you can re-route the bass causing the rattle to a bigger speaker on the floor, or behind something. Home-built is quite possible, and it doesn't have to be huge to make a big difference.
Mar 22, 2009. 5:09 PMlemonie says:
"Buzzy"? That'd be the speakers, rather than vibration in the books? They look pretty chunky, but pump enough power and you can overdrive anything I suppose... L
May 20, 2009. 5:29 PMf3rg says:
Cool project, Technochiken.
May 20, 2009. 5:26 PMCletusSpuckler says:
Great Idea.
1-40 of 47next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
87
Author:Technochicken(BuildIts)
