3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Book Wall Hangings - Flatlands - cube
Take one of the many beautiful books available at project Gutenberg and convert it into a wall sized readable book. Makes great gifts for the literary types in your life.
This is the complete text of Flatlands, and how to generate and print it, at 60 x 42 inches. That's huge!
Take a look at the PDF.
Step 1Select a book text you like.
Choose a public domain book from http://www.gutenberg.org/ or some other text source.
for example: Flatlands: http://www.gutenberg.org/etext/97CreatorAbbott, Edwin Abbott, 1838-1926TitleFlatland: a romance of many dimensionsLanguageEnglishDownload the txt file.
30 comments
Aug 1, 2007. 9:29 PMthreecheersfornick says:
Is there a good illustrator alternative that I could use? ...say, The Gimp?
May 25, 2009. 5:41 PMmwwdesign says:
Yup, called Inkscape.
http://www.inkscape.org/
May 25, 2009. 6:04 PMthreecheersfornick says:
It's funny, because since I left that comment, I've spent hours drawing things in inkscape!
Feb 15, 2007. 1:05 AMbgschiller says:
can anyone think of a way to do this, but in multiple colors making complex shapes? like pointillism, but with text. I guess what i mean is, doing the same thing as you did, but the text going straight across regardless of shape just changing in color. I don't think i'm expressing myself very well...
Apr 30, 2007. 1:50 PMedukdu says:
you will have to paste the text on photoshop...then choose the image..and you will fit the text to image as you like, then you select the text with Ctrl + mouse click over the text layer, then everything will be selected, now you click on the image layer and press Ctrl + C, Ctrl + V...and now you have a text with texture...from the source image...i will try to made a picture...
Apr 30, 2007. 2:44 PMedukdu says:
OMG...i used printscreen to make the images....it has 468Kb...its an animated GIF...I cant upload....anyway... the final result...Tadã...
Apr 30, 2007. 3:12 PMedukdu says:
finally....got the link...was a problem with the attachment of the gif...strange...
Example Tutorial
See ya
Edu Gomes
Mar 4, 2007. 1:40 PMDucky_2010 says:
I think I understand you. You want a big block of text, and different colors within the text making the shape? I think it could be done with photoshop. Make a giant text box with one layer, the shape on another, then use the magic wand and fill with color of choice. I'm not sure how to explain it, but I think it can be done.
Dec 5, 2006. 2:54 PMmunkey_b0y says:
I'm new to both Inkscape and Ilustrator, and I can't work out how to actually create a shape that I can add text to, it just seems to add the text in a regular rectangle of it's own. When I try using the area type tool it tells me it is the wrong type of shape. so any help would be greatly appriciated. The end result I'm trying to get is a shape of a raven with 'The Raven' by Edgar Alan Poe written in it. cheers
Sep 29, 2006. 2:12 PMzachninme says:
I find it ironic how you are turning Flatland into a cube :-P
Aug 23, 2006. 3:36 AMMauiChris says:
There is a program called Rasterbator for making large banners or pictures out of small ones.
It figures out how to space the file out onto however many pages you want and you print them and cut the border off and paste it all up (or if you can print to the edges... do that.)
http://homokaasu.org/rasterbator/
Aug 9, 2006. 1:04 PMhivoltage says:
wow this project is awesome. i made a wallbook out of The time Machine. i used the large printer at my dads work. it has to be printed pretty huge at a high resolution to be readable tho
Feb 5, 2006. 5:17 PMDELETED_Hellahulla says:
(removed by author or community request)
Aug 1, 2006. 4:24 PMhivoltage says:
you can extend the usable time of the free evaluation version of illustrator indefinately with a patch i have. i can email it to you if you are interested. its how i got my copy of illustrator
Jul 11, 2006. 4:15 AMchristoforos says:
Really nice work. I plan to print a tux made of linux 1.0 kernel as soon I get access to a large printer. This is how i got my txt with the source code in linux:
- Downloaded http://www.kernel.org/pub/linux/kernel/v1.0/linux-1.0.tar.bz2
- Extracted it by running "tar -jxvf linux-1.0.tar.bz2"
- Deleted uneeded file by "rm -f linux-1.0.tar.bz2"
- running this bash script:
#!/bin/bash
for i in $( find ./linux ); do
echo $i: >> out.txt
cat $i >> out.txt
done
- Follow this instructable on out.txt to remove whitespaces
You could obviously use a more recent kernel release, but it would dramatically increase filesize. I chose 1.0 because that's where it started ;)
Jun 25, 2006. 10:23 PMcookiedough says:
Incredible.
Dec 20, 2005. 5:50 PMnd says:
Use inkscape (inkscape.org) -- works fine for me. Maybe I will post my files here...
Jan 3, 2006. 10:34 PMehntoo says:
nd: any tips on doing it with inkscape? I plan on doing a poster with the text of the first Hitchhiker's Guide to the Galaxy, all overlayed onto a inkscape-traced copy of the thumb. I'd pick up a copy of illustrator, but I'm rather too broke at the moment.
Jan 1, 2006. 5:46 PMcmhdave73 says:
I've been trying to figure out how to do this with inkspace myself... instructions for that would be great.
Dec 16, 2005. 2:47 PMel kabong says:
This is a fantastic idea that I'd like to make as a christmas present. There are only two problems for me: 1- I think my machine is too slow 2- I would likely be using gimp or photoshop, not illustrator any suggestions as to minimum system requirements or how to do this in one of those other programs?
Dec 4, 2005. 11:00 PMfatecreatr says:
i'll probably seem like a complete idiot but everytime i go to paste the text into either photoshop or illustrator it only seems to take a certain amount before it all dissapears and is unusable. is there a maximum amount of text i can enter? anyone know what i'm doing wrong?
Nov 28, 2005. 10:11 PMrougewisp says:
Arg, Photoshop is my forte, not Illustrator. Can someone help me with trying to get the text to apply to a certain shape?
Dec 1, 2005. 1:52 PMerpsy says:
First create your shape, most any shape will work. Then select the area type tool. It is the large T in the squiggly box 'under' the regular type tool (you can use the regular type tool, it will become the area type tool when you click on a shape). Click on you shape (you have to click the edge of the shape). You will get a flashing curser indicating that your shape has become a type block. Start typing or paste text from the clipboard.
Nov 28, 2005. 12:45 PMpacifisticuffs says:
So after you paste in the text, did you rotate the shape, create the white separating lines and then color the different blocks?
Dec 1, 2005. 1:37 PMerpsy says:
Illustrator provides a great way to flow text. First, create all of the shapes that you want to fill with text. Select your first shape and paste your text into it. If there is more text than will fit into that shape, a small box with a + sign will appear at the bottom right corner. Then, select all of your shapes and go to Type->Blocks->Link. This will create a single type container using all of your shapes, allowing you to change the formating of the text to flow between and fill up you shapes.
Nov 28, 2005. 11:04 PMkiteship says:
You can get a 42" print at any Kinko's (and surely elsewhere). Color, too, and you can email your file + order online, than pick up the finished goods (I have no connection with Kinko's; use your local shop if you can) Way cool, Saul. I assume this is the same way you did your Origin of Species poster. killer!
Nov 28, 2005. 8:43 PMwipeout says:
If you have copy of Textpad it will remove all the line breaks etc in one move. Under the edit menu, just select join lines. Then all you have to do is replace the extra blank spaces. It is much easier to use and quicker than Word. Thanks for the great idea, working on one now as a present for my wife.
Oct 15, 2005. 12:11 PMeleraama says:
I did this using Adobe Photoshop, turning some text from Ambrose Bierce's "Devil's Dictionary" into an american flag. (I ended up making the background black for greater visibility of the image), and I must say that it looks fantastic. Thanks! (Printed it on a 8.5x11, so I couldn't get all the text, but it gets the effect across)
Sep 1, 2005. 8:32 PMEvolutionKills says:
That's an extraordinary idea. Very attractive. I just wish I had a large-format printer. Maybe tiling it and aligning the tiles behind a big piece of glass would work. Have you tried any alternatives?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
110
Author:saul
