A leather/metal wrap to protect a paperback book.
When I commuted to work on a train I enjoyed reading but my books got damaged whilst in my ruck sack. Here I describe my solution, a leather and metal book wrap.
Step 1: Materials
Materials:
  • Leather
  • Metal
  • Needle & thread
Tools:
  • Sharpe knife for cutting leather
  • Drill
  • 2mm drill bit
Optional:
  • Leather punching tools
  • Hammer
Notes:
Leather
    The leather came from ebay and was a handy 210mm x 295mm so mine didn't need cutting to size. A sturdy pair of scissors could be used to cut the leather depending on thickness but a knife can be cleanly run along the edge of a metal ruler to give a clean true cut.
    I've made a couple of covers like the one above and think that leather of at least 2mm thickness works best.
Metal
    I've used aluminium sheet for the one pictured but anything flat will do! The aluminium is a couple of millimetres thick and has held up relatively well to the abuses of being in my bag.
Leather punches
    Can be home made from a nail, instructable to follow.
Step 2: Measure & cut
Measure your books
The majority of my paper backs are around 110mm - 130mm wide and 180mm - 200mm tall. Cut your metal backing piece so that it is ~10mm taller and 5mm wider than the biggest book you're likely to want to carry. This overhang will hopefully protect the corners of your books.
With the metal of the correct size cut the leather. I've left 5mm top and bottom.
The width of the leather depends on how thick you like your books. Mine is 570mm, but this was mostly determined by the leather I had available. This goes around a good sized book one and a half times.
Step 3: Drill & sew
Mark holes for drilling
You could glue your backing plate to the leather but I prefer to sew it on. Mark one edge of the metal every 7mm, my aluminium sheet was soft so a small nail and a firm hammer were used to mark the point and provide a centre for the drill.
I find leather much easier to sew when the holes are made with drill or pierced with a nail. Forcing a needle through two thickness's of 2mm leather runs the risk of snapping a needle and stabbing a hand. So mark holes 7mm apart and drill or pierce.
If you have a drill press or a steady hand you could clamp and/or glue the leather and drill through the whole lot.
Sew the bits together and you're done! I used strong cotton thread doubled and something approaching a saddle stitch.
Step 4: Tool the leather
Optional decoration
With a nail punch I've added an oak leaf, acorn and mushroom pattern to the leather to make the join a little more attractive.
This kind of embellishment is quite basic but it can be done fairly quickly and cheaply and I like it :) To make something like this, wet the leather with water, hammer the punch, repeat until happy.
The leather punches are home-made, the idea came from a book and I'll have a quick instructable on them some time.
star_above_the_clouds says: Nov 26, 2010. 11:35 AM
This looks very nice!
Nostalgic Guy says: Oct 17, 2010. 5:19 PM
A nice idea I wish I had one when I travelled to work by train all the time, sharing a bag with a laptop & all my cables & other paraphernalia did not do my books any favours at all.
When I first started to work with leather I would score my stitching line with the back of a butter knife then use the sharpened tines of a steel fork to mark my holes I still use this method occasionally but now have a wheeled stitch marker for the job. If you are going to do a lot of leather work you may find something like this useful. It helps to keep the stitches straight & if you score the line deeply enough your stitching will be flush with the surface of the leather.
I still carry books in my backpack when I know I will have a long wait for an appointment or I am travelling so I will probably make something similar, I like the idea of velcro but I may substitute the aluminium for a thin steel plate & use a couple of hard drive magnets for the closure.
Phil B says: Oct 14, 2010. 8:38 AM
Could you add a Velchro closure?
cbm104 (author) in reply to Phil BOct 15, 2010. 10:07 AM
Yes, velcro could be a handy addition. I used an over sized wrap because it works for books of any thickness or multiple books, with velcro fastening you might use.one strip vertical on the inside edge and one horizontal on the outside.
Phil B in reply to cbm104Oct 15, 2010. 11:25 AM
I was looking for something like this about a month ago. I finally settled for making a slip case from some nice wood. It allows me to include a companion volume in the one slip case.  Click on the link above to see is as an Instructable.  It is serving me well, but I still like your leather cover.
Phil B in reply to Phil BOct 15, 2010. 11:26 AM
Correction to my comment above: "to see IT as an Instructable..."
seolfor says: Oct 13, 2010. 1:45 PM
Very nice!
cbm104 (author) in reply to seolforOct 15, 2010. 9:57 AM
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
