Step 2Attach Plywood
Mark on the plywood where you will be drilling. Put two screws in each corner of the plywood and shelf. I measured it out so the screws would be exactly the same distance from the corner and in the middle of the shelf frame (i.e. the thickness of the frame of the shelf and the shelves is 2", so the screw is 1" from the edge )
Drill a starter hole for the screw so the wood doesn't split and the screw goes in easily. Then drill the screws in.
Sorry about my final picture. I took it at a weird angle and thought I would be able to just rotate it 90 degrees, but it didn't look good (or give me a headache) at any angle but this.
comment
Add Comment
Add Comment
